Problems with F@H clients.
Syribo
Been having problems still with F@H ;)
Wrote about it in the 'mugs' thread... (This is my third day since joining the [H]orde!) I was using the graphical client, but I tried downloading the SMP client (I think it is the right one..) And this is what happens when I try to install:
OpenSCManager failed:
Access is denied. (error 5)
Unable to remove the previous installation, install failed.
account (domain\user) [Zero\Stickable Stars]: Stickable Stars
password:
confirm password:
Password encrypted into the Registry.
Unable to connect to 'Zero:8676',
sock error: generic socket failure, error stack:
MPIDU_Sock_post_connect(1228): unable to connect to Zero on port 8676, exhausted
all endpoints (errno -1)
MPIDU_Sock_post_connect(1275): unable to connect to Zero on port 8676, No connec
tion could be made because the target machine actively refused it. (errno 10061)
Press any key to continue . . .
:( I want to get this SMP client to run because hopefully it will stop shutting down every time I'm done with a WU. Help me and I love you long time? ;)
Couple questions:
Which version of windows are you running?
Do you have the .NET Framework v2.0 installed?
Where are you attempting to install the client?
Do you have Vista? If so, turn off UAC.
You can turn it back on later.
Couple questions:
1. Vista 64-bit
2. Uhm.. I'm.. not sure :eek: If it didn't come either with Vista or an update or SP1, then no.. I don't think I have it.
3. Trying to install it on my C drive (I have two HDDs right now), trying to install it on the drive with the OS.
I checked your sig... so you have Vista 64 bit?
We should be able to solve this. I have many Vista boxen running the SMP.
Vista comes with the .Net stuff. No worries there.
Try to install it in a new unique directory, like this:
c:\folding
or
c:\smp
good luck
Okay I'm going to try installing to a new directory next.. I tried just turning off UAC and I got this when I tried to install:
Stopping MPICH2 Process Manager, Argonne National Lab.
MPICH2 Process Manager, Argonne National Lab stopped.
MPICH2 Process Manager, Argonne National Lab removed.
MPICH2 Process Manager, Argonne National Lab installed.
password:
confirm password:
Credentials for Stickable Stars rejected connecting to Zero
Aborting: Unable to connect to Zero
Windows: V5 Beta SMP clients
Windows XP/2003/Vista/2008 SMP client console version 5.91 beta6
I think with Vista 64 you must use 5.91 and don't use 5.92.
Ya, I found this:
*other notes*
5.92 does not currently support 64-bit Windows. This is something we will work on in the future.
Sorry this is so beta-ish. It happens!
Make sure you reboot after turning UAC off. The change requires a reboot.
I hope you d/l'ed the 5.91.
This is really complicated.
It's okay :) I'm using the 5.91, not 5.92.
I uninstalled, and installed it again to C:/folding and got this again:
password:
confirm password:
how about install.bat?
Did that run correctly?
And you have a password on your account, and of course you put in your username and password the same as what Vista recognizes?
just grasping at straws....
Yup! :( Did that too! Something is up... and I can't figure out what!
Should I try putting the SMP client on my other computer too? It's still folding right now, using the graphical one. That computer is using XP 32-bit.
password:
confirm password:
This is where you are going wrong.. when it gives you the user name just hit the enter key.. then type in your password.. you are unknowingly changing the user name
Tried just pressing enter, then a password... Still the same thing happens. Should I try uninstalling it, again, and installing it, again"?
Hmm, definitely some type of authentication issue. Are you positive that the password you are entering is the same exact password as your Vista password?
I don't know anything about domains. What is the "zero" domain that you have?
Zero sounds like it should be her computer name.
Yes, sorry I should have confirmed that :) Zero is my computers name, and Stickable Stars is my Vista Account name.
[H]ugh_Freak;1032434182 said:
Stickable Stars does have a password? And it is an admin account?
Yup. And I've been entering the correct password.. :(
Gasping at straws at this point but do you have any anti-virus or anti-spyware apps running?
I think it may be due to the space in the user name. Try to make a new one with no space and with a password then test with this one.
BTW, welcome to the [H]orde, we are proud to have you with us as the other young women ;)
BTW, welcome to the [H]orde, we are proud to have you with us as the other girl ;)
Hey good brotherman Xilikon, I'm certainly not being "all knowing" but I've learned the [H]ard way to never call a young woman a "girl" :eek:
Something about the "womans scorn" thing again. ;)
Sorry if this is "off topic" :(
Hey, as long as I'm not being called 'maam', it's all good! :p
account (domain\user) [Zero\Syribo]: Syribo
password:
confirm password:
Credentials for Syribo rejected connecting to Zero
Same thing happens, even with a new account with no spaces.. :( I'm going crazy! All this wasted time (And I can't get the graphical client to work either, it hasn't in two days).. The other is still folding (Not using SMP) but still.. I must get it to work on this computer also somehow. :(
I guess the networking config is borked...
Are you connecting the box to a domain or only on the workgroup ?
Workgroup, I think? Modem -> Router -> This box, my 2nd one and my fathers laptop (wireless). They're all on the same network.
Can you take a screen shot of the page with the network config (computer and workgroup name) ?
You're still typing in the user name?
Oh, no no.. I tried it without typing it in at first, and then since it didn't work, I thought I may as well try to type it in.. Since nothing has worked so far :)
I use Network Magic... I can take a screenshot of that, or just copy all the details from NM itself:
Wireless Router (D-Link)
Network Name: My Network
Status: Online
Manufacturer: D-Link Systems
Model: DIR-655 A3
Firmware: 1.10, 2007/09/04
Network Identifier (SSID): Fast New Guy
Connection Name: Local Area Connection 2
Wireless Security: Disabled
The New Guy
Workstation
Computer Name: Zero
Connected Via: NVIDIA nForce Networking Controller #2
Connection Speed: 1000.0 Mbps
Operating System: Microsoft Windows Vista (x64 Home Premium) SP1
Processor: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Memory (RAM): 4096 MB (( I just noticed that it says I have 4096MB of RAM.. I actually have more than that.. Hm ))
I don't think you need the details from my fathers laptop or my other computer? Heh.. Is this the info you needed? If you need more, let me know!
Edit: I know it probably has nothing to do with it.. but I never installed any updates for Nvidia Networking Controller. There are some in my Windows Update that I never installed because I remember someone telling me not to.. Hmmmm.
