cephalalgia
- Dec 20, 2006
Yesterday I got the blue screen of death with an error message that Windows must shutdown to prevent damage to my hardware, if this problem persists contact your hardware manufacture or something to that extent
So the first thing I did was check the ASUS website for a BIOS update. My Mobo is an ASUS P5P800 and the current BIOS version is 1202. I found version 1401 was available and downloaded it. Being that I dont have a floppy drive on this box I followed this tutorial for a BIOS Update boot CD http://www.biosflash.com/e/bios-boot-cd.htm and used AFLASH.EXE as recommended by the ASUS website seen here http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
The Boot CD boots to DR DOS, but when I run the BIOS Flash program I get the following error: Error! Cant Find System BIOS Hook. After searching the web for that error I came to the impression that I am using the wrong BIOS Flash software
Can anyone help me out with this problem. Am I using the right BIOS Flash software for the P5P800, if not, what is the proper Flash software? If I am using the right software, could it be that the DR DOS Boot is messing with the BIOS Flash software, if so can someone point me to a DOS Boot for a CD that I can use effectively to boot into a DOS prompt from CD and access my BIOS flash files from the same CD?
If you can think of anything else that could be causing the problem with Windows (XP 64) please let me know. Thanks!
