Hey guys, Im having some issues with my geforce's... For some reason when in SLI mode, videos will flicker and some just wont work and it gives me a "cannot find video card" error... Any suggestions? im using the latest forceware drivers released.
Forceware 158.18
Windows Vista 64-bit
Dell 7900gs's that I think are XFX's
The video will flicker black every other frame and it only does it in AFR mode of SLI. In split screen mode it will show nothing, and in single Gpu mode it will show the video normally. It only does it on certain videos for whatever reason I have yet to figure out, its not limited to one codec either.
You have tried each card by itself and they have no problems? Try a video card alone in the second PCI-E x16? Also does a previous driver version also have the same problem?
When SLI is turned off it work perfectly, Ill see if I can hook up the bottom card itself soon to see if thats a problem.
I dont really remember if the earlier drivers had the same issues... The last one nvidia released did the same things, (the offical ones before 158.18) and before that SLI wasnt in the drivers from what I remember... It didnt do it at all on Windows XP.
