Prozac1964
- Feb 1, 2010
Hey everyone. I'm frustrated. After using Windows XP for 10 years straight, I finally upgraded to Windows 7. I love it overall, but some odd things are happening. For example I've been playing Unreal Tournament 2004 since the day it came out so naturally I installed it on my new OS, Windows 7.
However when I navigate to the UT2004 directory none of the files I used in UT2004 using Windows XP, are present. Files like user.ini and ut2004.ini are simply not there. But I did notice some files called Configuration Files look like they may possibly be the missing files but since the name of the file is wrong and there are no .ini file extensions I don't know what is what.
I did a search from the start menu for "user.ini" but it yielded nothing. Does Win7 change file names when you install it?
Oh well, thanks for any help you can provide.
