Problem with WHS Norco 4020 build
perium
Hi all, after reading about the norco case and the supermicro SASLP-MV8. I decided to build my own. I am having a issue with using the supermicro controller where the drives just dont recognize in the bios. I have went ahead and removed the drives from the backplane and connected them directly to the supermicro controller, and tried this with two seperate drives. My guess is I got the wrong mini-sas to sata cable, here is what I ordered. http://www.newegg.com/Product/Product.aspx?Item=N82E16816133033 Is there a different cable I need, or should I be looking at something else for my issue?
Not 100% sure but I think you need the forward version:
$18 - 3ware SFF-8087 to Multi-lane SATA Forward Break-out Cable
i was just reading about the forward cable, im going to order one and see if thats the reason.
