I just put together a newly built system for my little brother.. Which consists of the Gigabyte DS-3 motherboard...
After I got everything installed and plugged in, I turned on the computer for the first time.. everything seems fine, but for some reason when I try to enter BIOs or whatever, it would freeze on the Gigabyte Start-Up Screen... so I keep trying to restart, and I'll try to enter the Boot Menu when it shows me the Start-Up Screen... once again, it'll freeze... so if I don't press anything, it'll boot, but then it'll show the BIOS POST Start-up screen for no less then a second and continue... After that it would just sit there and freeze again... after awhile of messing with it, I got it to boot the windows xp pro cd... (I did notice it was very slow on entering the Windows Set-up), after I reformatted the drive, it continued to install windows... Then I got the blue screen!! So I restarted again, and did it again.. this time I went to about 40% installed, and it kept saying "This file cannot be installed" So I tried to skip it, but it wont let me.. it seemed as if the CD drive wasn't even running.....
Can anyone help me out here? If you can help me to get it to work, I'll be generous and paypal you some tip... Thanks so much.. (got a big headache =(
