Problem with MSI Platinum v.2 975x
D_A_M
This is my first build so maybe I'm just doing something wrong. I've got everything hooked up and can fire the PC up, but if I change pretty much anything in the BIOS, it won't let me access the BIOS again unless I reset the CMOS. Instead it skips the option for me being able to enter setup or BIOS and goes through checking installed components and then gives me this message:
Intel Boot Agent
(stuff about the version)
PXE-E61: Media test failure, check cable.
PXE-M0F: Exiting Intel Boot Agent
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER
Also, here's the specs of what I'm using:
Core 2 Duo E6400 (w/ stock cooling)
DDR2 PC6400 Corsair XMS 1gb
Plextor DVD Drive PX716-AL
120gb SATA Samsung HDD
Sapphire X1900XT 256mb
Ultra V 600w PSU
Any idea what's going on? I've checked the cables and they seem to be hooked up properly. I'm probably going to reset the CMOS again and go into BIOS so what exactly are the settings I need to change? The reason I ask this is because the instruction book sucks like you wouldn't believe and I'm going on a magazine article that's pretty vague itself. If I can, I'll try and take a pic of what the screen looks like in the morning. Help would be GREATLY appreciated :(
Thanks for the link to that thread. Here's what my problem looks like...
Make sure your specifying to boot from the HDD in the BIOS. That was a common mistake I made, when I used an MSI board.
I've got the boot sequence set up to boot the HDD, then the CDROM (I don't have a floppy). I still get the same error. One thing I did "fix" was originally it was detecting the HDD as the IDE Third Master and now I've got it detecting as the Primary Master (not that it helped). Any other ideas? MSI's tech support is useless.
I'd make sure your SATA drives are set to IDE mode. Turn off the Intel Matrix storage.
Where would the Intel Matrix storage option be? I don't see anything on it. Also, the SATA drives do seem to be set to IDE.
