problem with computer after overclock...
Xenozx
Hi, recently i overclocked my computer via the fsb by 2 per boot. i was at 226 fsb and everything seemed to be ok. I then went to 228 and boom. my computer wouldnt boot. It appeared as tho my computer stopped detecting my raid drives. I then went back to 224 and it then detected the drives again but said that my windows/system was damaged and to try to repair the files via windows recovery console from the XP cd. i then tried to go all the way back to 200 and still kept getting the same message. I finally decided to use the recovery console but it was really hard to figure out. i did a chkdsk /p command and it found one error on the volume of my partion with the raid set and it fixed it but i was still getting the same thing. I finnaly said screw it and decided to reinstall windows. the wierd thing was when i went into reinstall windows on the one partition it said it was an unknown format instead of NTFS. i thought this was strange. anyway im now on the new format thing and everything is looking good. im now down to 218 fsb but im wondering what could have happend?
Is my SATA baracuda drives in raid 0 config run off my FSB? if so how can people pull 230+ fsb if my computers kicking out at 228?
any idea how to fix the files on the hard drive rather then have to completely reformat if something like this happends again?
I have a 3500+ and an asus a8v deluxe with 512x2 corsair 2-2-2-5 ddr 3200 mem and a 520 watt vantec stealth power supply. 2 seagate baracuda 7200 rpm 8m sata harddrives in raid 0 config.
Im using the via raid controller.
any ideas how to increase my overclock without running into problems like this? and any answers to the questions above?
I'm not that great at overclocking.. but maybe you screwd the RAM up?? and then it got loaded with screwed data that got written into the HDD??? i would have gotten PC 3500 RAM if i were to pass 200 FSB..
as for fixing the files.. i have no clue.. maybe you shoudl have posted in the software section
the reason i bought this ram is because ive seen many reviews that say by laxing the timings you can get it up to close to 600 mhz. its clocked at 400 stock and i changed the timings to 2-3-2-6 hopeing to get 460 out of it. but apparently im not able to go over 250.
Sometime overclocking will corrupt system files. It happens. Reload and stay at 226, not to shabby. What are your system specs?
because if this i figured i could go alot higher 8(
Does your MB support a PCI/AGP lock, because otherwise I am suprized you got as far as you did.
==>Lazn
I cant even remember how many times this has happened to me due to extreme overclocking. Just reload and take a different approach till you get it right. :D
And by the way AMD likes 2.5. Try 2.5-2-2-5.
right now i have mine running stable at 240x10 with a 5:4 divider
temps are alittle high for my liking, i am going to replace the 80mm fan with a higher output 90mm fan. tomorrow i am going to push for 250x10. the pci/agp bus lock seems to be working good.
that kinda tells me that there is a pci/agp lock but i dont think those are my problem currently, it seems like its my raid devices. now do on board raid controllers have a lock or do they run off of the pci/agp bus?
also if the agp/pci run off the FSB does that mean ive overclocked my AGP bus and am i getting more bandwidth from it then what normal 8x mode would give you?
the pci/agp lock has 2 options. 66.66/33.33 an 75.4/37.7. if i did want to lock it and try again which option woul i go to? i believe agp and pci are 66/33 but why do they have the second option there?
The RAID runs off the PCI bus.
If you do not lock your AGP/PCI yes you do get more bandidth through them, but not all devices will run at these higher speeds. (like your RAID chip)
66/33 are the normal AGP/PCI speeds, if it has a higher speed lock, it would be so you can run the AGP/PCI faster, if the devices can handle the higher speeds.
==>Lazn
Heres what happened:
As your bios booted from your hard drive, windows began to load, and began applying stress to your cpu. The cpu either didnt have enough voltage, or just couldnt run at that FSB, and as the hard drive was reading a sector, the system rebooted, causing the hard drive needle to magnetically corrupt the sector it was hovering over. Lucky for you, it was a windows file. The same thing happens sometimes when people think theyre computer has locked up, but the hard drive is very busy, and they hit the restart button and corrupt a sector. Sorry for you loss.
i see so if my PC is busy then dont be shutting it off, does reset help?
ok so i have to get this agp/pci lock thing working and ill probably be able to overclock a little bit higher?
Is there any benifit of overclocking the pci/agp bus? can you get more bandwidth with the agp overclocked?
sorry i didnt see you mention the more bandwidth thing.
one more ? if my computer kicked out at about 226 fsb without the agp/pci bus locked then what where there frequencies at 226 fsb?
Depends on what devider your MB uses at that speed but just a guess: around 75mhz AGP and 37.5MHZ PCI (assuming the same devider of 3 as it would use at a 200mhz FSB)
==>Lazn
Are you sure?
This seems like a curious explanantion, and there are several things I don't understand. Maybe you can clarify them for me.
Why would a system reset during a read cause any magnetic activity in the drive head? I think that the hard drive's transport mechanism resets asynchronously from the rest of the system.
The head doesn't hover over a sector. The drive is constantly spinning. Even on a slow 5400 rpm drive, the heads are over every sector on a cylinder 90 times a second.
Maybe I'm misunderstanding your post; what's a "hard drive needle"?
.B ekiM
ok im looking for performance. so assuming im at 220x11 stable and have a bit of an overclocked agp port. would i be better off agp/pci locking it>? and increasing the speed of my processor from 2.42 ghz to say 2.5 or 2.55. I think thats the theoretical max for a 3500+ but would i be better off with the more processor speed or the agp overclocked a bit. (im asuming processor but figured id ask anyway)
also any idea's how to enable a agp/pci lock on an A8V and what bios i might need to do it?
Thats some pretty optimistic timings...
Lock the AGP/PCI and overclock the CPU more. You get much more out of a higher CPU speed, and a higher FSB speed.
The performance gains of overclocking the AGP/PCI bus are negligable. (measurable, but barely)
==>Lazn
yea its suppose to, but i heard its in a different bios version then the one i have. or you have to do a trick or something to get it to show up. I made another post so i wouldnt worry about it. Thank you Lazn for all your help.
installed bios 1005.21 and everything is gold now. im at 2.5 ghz and still runing idle/load temps of 30/42. pretty sure i got more head room will let you guys know how everything works.
im at 230x11 2.53 ghz stable.
Wait a minute... are you counting that with DDR memory, the mhz are considered doubled? (Double Data Rate)
For example, a system on a 200mhz fsb would have 400mhz DDR clock.
So to get to the 460 mhz you want, you would have to reach 230 fsb, which it sounds like you already reached. 250 fsb is 500 DDR, which is extremely fast, especially at 2-3-2-6 timings. In fact, I didn't even think that was possible.:eek: The average latency for DDR 500 seems to be around 3-4-4-8.
Oh well, either way, it seems you got it worked out.
