Hi folks,
I have two questions and I'll keep 'em short
1) Has anyone experienced an ARC-1880 dropping an entire enclosure? System (running in a Norco 4220 chassis) has been running steady state for a year with zero problems but the first failure occurred when I upped the total disk count from 13 to 15 and was expanding my primary array from 9 to 10 disks (RAID-6). Now it just happened again, not sure what the system was doing which leads to my second question...
2) After the failure during the expansion, my primary array is in a "Failed Migration" state. After some jimmying around (I didn't do much, pulled the new drives, swapped them around, etc), the last time I rebooted the server last night I got an entry in the event log that said "Rebuild RaidSet" and nothing else for around 18 hours. During that time, the Raid Set Hierarchy page continued to say "Failed Migration" for the state (in other words, it did NOT change to "Rebuilding (xx%)" so I don't know if it was actually rebuilding. Is there any way to tell if it was actually rebuilding the RaidSet or was I leaving it along and was it just sitting there? And the corollary question: is there any way to force a rebuild when the state is semi-hung like that? I mean it only got like 10% into rebuilding and since it's a RAID-6 array, failure during expansion should be immediately reversible shouldn't it? But yet no magic command that I could find to do so.
I also sent an email to Areca support, but since it's the weekend, thought I might get some helpful ideas here somewhat faster.
Annotated event log posted below for reference. Any more data that could be helpful, I can provide as well.
Thanks everyone!
Jason
Raid Set # 000/ARC-1880-VOL#000 - primary array, RAID 6, was 9 matching Samsung drives, added 1 to the array at the start of this trouble, kept an 11th in reserve as a hot spare, Enclosure #2 (not sure what enclosure 1 is), Originally Slots 05, 09-16, added drives in Slots 06-07, designated one for expansion, one for hot spare. Have rearranged those two drives ONLY since.
TVRecordings/TVRecordinVolSet - secondary array, RAID 0+1, four matching Toshiba drives, Enclosure #2 (not sure what enclosure 1 is), Slots 01-04.
2012-07-29 14:37:58 192.168.135.053 HTTP Log In
2012-07-29 14:10:16 TVRecordinVolSet Start Rebuilding
2012-07-29 14:10:14 TVRecordings Rebuild RaidSet
**** It doesn't show up here but I declared the drive in Slot 1 as a hot spare so the secondary array grabbed it and started rebuilding. Note that it didn't try to start rebuilding the primary array this time.
2012-07-29 14:08:43 Proxy Or Inband HTTP Log In
2012-07-29 14:04:33 H/W Monitor Raid Powered On
2012-07-29 14:00:41 192.168.135.053 HTTP Log In
**** Rebooted server after enclosure disappeared
2012-07-29 14:00:15 Enc#2 SLOT 03 Device Removed
2012-07-29 14:00:15 Enc#2 SLOT 02 Device Removed
2012-07-29 14:00:15 Enc#2 SLOT 15 Device Removed
2012-07-29 14:00:15 Enc#2 SLOT 14 Device Removed
2012-07-29 14:00:15 Enc#2 SLOT 13 Device Removed
2012-07-29 14:00:15 Enc#2 SLOT 12 Device Removed
2012-07-29 14:00:15 Enc#2 SLOT 11 Device Removed
2012-07-29 14:00:15 Enc#2 SLOT 10 Device Removed
2012-07-29 14:00:15 Enc#2 SLOT 09 Device Removed
2012-07-29 14:00:15 Enc#2 SLOT 07 Device Removed
2012-07-29 14:00:15 Enc#2 SLOT 05 Device Removed
2012-07-29 14:00:15 Enc#2 SLOT 04 Device Removed
2012-07-29 14:00:15 TVRecordings RaidSet Degraded
2012-07-29 14:00:15 TVRecordinVolSet Volume Failed
2012-07-29 14:00:15 Enc#2 SLOT 01 Device Removed
2012-07-29 14:00:15 Enc#2 SLOT 16 Device Removed
2012-07-29 14:00:15 Raid Set # 000 RaidSet Degraded
2012-07-29 14:00:15 ARC-1880-VOL#000 Volume Failed
2012-07-29 14:00:15 ARC-1880-VOL#000 Volume Degraded
2012-07-29 14:00:15 Enc#2 SLOT 06 Device Removed
2012-07-29 14:00:14 Enclosure#2 Removed
**** Entire enclosure disappeared and the drive located on the previously functioning secondary array vanished.
2012-07-29 14:00:02 Enc#2 SES2Device Time Out Error
2012-07-29 13:59:48 Enc#2 SES2Device Time Out Error
2012-07-29 13:59:17 Enc#2 SLOT 01 Device Failed
2012-07-29 13:59:17 TVRecordings RaidSet Degraded
2012-07-29 13:59:17 TVRecordinVolSet Volume Degraded
2012-07-29 13:54:42 Enc#2 SLOT 01 Reading Error
2012-07-29 13:54:24 Enc#2 SLOT 01 Reading Error
2012-07-29 13:53:58 Enc#2 SLOT 01 Time Out Error
2012-07-29 13:53:03 Enc#2 SLOT 01 Time Out Error
2012-07-29 13:50:54 Enc#2 SLOT 01 Reading Error
2012-07-29 13:44:08 Enc#2 SLOT 01 Reading Error
**** Was streaming video off the secondary array (watching a TV show) which started stuttering badly until it finally failed
2012-07-28 19:59:09 Raid Set # 000 Rebuild RaidSet
2012-07-28 19:59:09 Enc#2 SLOT 07 Device Inserted
**** Slid the drive in Slot 07 back into the chassis and the primary array picked it up and claimed to start rebuilding. However, no sign of activity and no change to the summary webpage which continued to just say "Failed Migration" so no way to know if it was really rebuilding the array.
2012-07-28 19:16:41 192.168.135.053 HTTP Log In
2012-07-28 18:57:20 H/W Monitor Raid Powered On
2012-07-28 18:53:38 192.168.135.053 HTTP Log In
2012-07-28 18:37:59 RS232 Terminal VT100 Log In
2012-07-28 18:37:25 H/W Monitor Raid Powered On
2012-07-28 18:32:12 Enc#2 SLOT 08 Device Removed
2012-07-28 18:32:11 Raid Set # 000 RaidSet Degraded
2012-07-28 18:32:11 ARC-1880-VOL#000 Volume Degraded
2012-07-28 18:29:49 Enc#2 SLOT 08 Time Out Error
2012-07-28 18:27:14 Enc#2 SLOT 06 PassThrough Disk Deleted
2012-07-28 18:21:23 Proxy Or Inband HTTP Log In
2012-07-28 18:19:28 H/W Monitor Raid Powered On
2012-07-28 18:18:16 Enc#2 SLOT 06 PassThrough Disk Created
2012-07-28 18:16:28 RS232 Terminal VT100 Log In
2012-07-28 18:16:00 H/W Monitor Raid Powered On
**** I decided I would try to reformat the drive that was originally a hot spare to clear any RAID information off it in the hope that it would use it to rebuild the primary array. Alas, it didn't seem to make any difference, other than I stopped getting Time Out Errors on it.
2012-07-28 16:14:32 Enc#2 SLOT 06 Time Out Error
2012-07-28 16:14:12 Enc#2 SLOT 08 Time Out Error
2012-07-28 16:13:59 192.168.135.053 HTTP Log In
2012-07-28 14:13:12 Raid Set # 000 Rebuild RaidSet
2012-07-28 14:13:12 Enc#2 SLOT 08 Device Inserted
2012-07-28 14:02:26 H/W Monitor Raid Powered On
2012-07-28 14:00:18 RS232 Terminal VT100 Log In
2012-07-28 13:59:34 H/W Monitor Raid Powered On
2012-07-28 13:54:09 192.168.135.053 HTTP Log In
2012-07-28 13:53:36 RS232 Terminal VT100 Log In
2012-07-28 13:53:18 H/W Monitor Raid Powered On
2012-07-28 13:49:25 192.168.135.053 HTTP Log In
2012-07-28 13:47:43 Enc#2 SLOT 08 Device Removed
2012-07-28 13:47:43 Raid Set # 000 RaidSet Degraded
2012-07-28 13:47:43 ARC-1880-VOL#000 Volume Degraded
2012-07-28 13:46:39 RS232 Terminal VT100 Log In
2012-07-28 13:45:46 H/W Monitor Raid Powered On
2012-07-28 13:29:11 Enc#2 SLOT 08 Time Out Error
2012-07-28 13:29:01 Enc#2 SLOT 06 Time Out Error
2012-07-28 12:42:54 H/W Monitor Raid Powered On
**** Started to do some experiments with pulling out and pushing in the two new drives. Also experimented with the command line and the BIOS setup to see if it had any additional capabilities.
2012-07-28 10:48:12 Enc#2 SLOT 08 Time Out Error
2012-07-28 10:48:02 Enc#2 SLOT 06 Time Out Error
2012-07-28 10:46:18 SW API Interface API Log In
2012-07-28 10:11:00 192.168.135.053 HTTP Log In
2012-07-28 09:55:29 H/W Monitor Raid Powered On
2012-07-27 22:59:21 192.168.135.053 HTTP Log In
2012-07-27 22:57:59 H/W Monitor Raid Powered On
2012-07-27 22:42:19 192.168.135.053 HTTP Log In
2012-07-27 22:27:11 H/W Monitor Raid Powered On
2012-07-27 22:24:47 RS232 Terminal VT100 Log In
2012-07-27 22:24:32 H/W Monitor Raid Powered On
2012-07-27 22:19:48 192.168.135.053 HTTP Log In
2012-07-27 22:17:38 H/W Monitor Raid Powered On
2012-07-27 22:14:48 TVRecordinVolSet Modify Volume
**** Renamed my secondary array to better be able to tell it apart from the primary
2012-07-27 22:10:13 RS232 Terminal VT100 Log In
2012-07-27 22:09:27 H/W Monitor Raid Powered On
2012-07-27 22:06:45 192.168.135.053 HTTP Log In
2012-07-27 21:31:36 ARC-1880-VOL#001 Complete Rebuild 003:32:34
2012-07-27 21:06:15 Raid Set # 000 Offlined
2012-07-27 20:50:43 192.168.135.141 HTTP Log In
2012-07-27 18:19:55 Enc#2 SLOT 06 Device Inserted
2012-07-27 18:19:43 Raid Set # 000 Rebuild RaidSet
2012-07-27 18:19:42 Enc#2 SLOT 08 Device Inserted
2012-07-27 18:19:42 Enc#2 SLOT 07 Device Removed
2012-07-27 18:19:42 Raid Set # 000 RaidSet Degraded
2012-07-27 18:19:42 ARC-1880-VOL#000 Volume Degraded
2012-07-27 18:12:13 Enc#2 SLOT 07 Time Out Error
2012-07-27 18:00:40 Raid Set # 000 Rebuild RaidSet
*** Notice that it claims to be building the primary raidset but it is getting timeouts from the new disks. So I decide to try moving them to a different slot to see if it will help.
2012-07-27 18:00:40 Enc#2 SLOT 07 Device Inserted
2012-07-27 17:59:01 ARC-1880-VOL#001 Start Rebuilding
2012-07-27 17:58:59 Enc#2 SLOT 07 Device Removed
2012-07-27 17:58:59 TVRecordings Rebuild RaidSet
2012-07-27 17:58:59 TVRecordings RaidSet Degraded
2012-07-27 17:58:59 ARC-1880-VOL#001 Volume Degraded
2012-07-27 17:58:52 Enc#2 SLOT 06 Device Removed
2012-07-27 17:58:52 Raid Set # 000 RaidSet Degraded
2012-07-27 17:58:52 ARC-1880-VOL#000 Volume Degraded
2012-07-27 17:56:36 Enc#2 SLOT 07 Time Out Error
2012-07-27 17:56:23 192.168.135.053 HTTP Log In
2012-07-27 17:46:13 H/W Monitor Raid Powered On
2012-07-27 17:17:45 ARC-1880-VOL#001 Complete Rebuild 003:29:38
2012-07-27 16:48:47 Proxy Or Inband HTTP Log In
2012-07-27 16:31:01 Enc#2 SLOT 06 Time Out Error
2012-07-27 13:48:07 ARC-1880-VOL#001 Start Rebuilding
2012-07-27 13:48:05 TVRecordings Rebuild RaidSet
**** Since I didn't want the samsung used in the secondary array, I purposefully fail it by pulling the drive and setup the original hitachi drive as a hot spare so that it rebuilds itself successfully. Now I'm back to a normally functioning secondary array, and a broken primary array but at least I have my expansion and hot spare disks back in place.
2012-07-27 13:48:05 Enc#2 SLOT 07 Device Inserted
2012-07-27 13:47:52 Raid Set # 000 Rebuild RaidSet
2012-07-27 13:47:52 Enc#2 SLOT 06 Device Inserted
2012-07-27 13:46:55 Enc#2 SLOT 07 Device Removed
2012-07-27 13:46:55 TVRecordings RaidSet Degraded
2012-07-27 13:46:55 ARC-1880-VOL#001 Volume Degraded
2012-07-27 13:46:50 Enc#2 SLOT 06 Device Removed
2012-07-27 13:46:50 Raid Set # 000 RaidSet Degraded
2012-07-27 13:46:50 ARC-1880-VOL#000 Volume Degraded
2012-07-27 13:38:30 192.168.135.053 HTTP Log In
2012-07-27 13:20:39 H/W Monitor Raid Powered On
2012-07-27 13:17:43 RS232 Terminal VT100 Log In
2012-07-27 13:03:37 RS232 Terminal VT100 Log In
2012-07-27 13:03:05 H/W Monitor Raid Powered On
2012-07-27 12:51:12 H/W Monitor Raid Powered On
2012-07-27 12:39:22 H/W Monitor Raid Powered On
2012-07-27 12:37:23 H/W Monitor Raid Powered On
2012-07-27 12:21:44 Enc#2 SLOT 06 Time Out Error
2012-07-27 12:21:32 192.168.135.141 HTTP Log In
2012-07-27 12:17:00 TVRecordings Offlined
2012-07-27 12:14:18 192.168.135.141 HTTP Log In
**** Now I notice that the rebuild/expansion of the primary array isn't starting back up so I panic and start pulling out the new drives and trying different reboot strategies, none of which work.
2012-07-27 02:50:17 ARC-1880-VOL#001 Complete Rebuild 003:29:53
2012-07-26 23:20:23 ARC-1880-VOL#001 Start Rebuilding
***** The secondary array is able to rebuild itself onto the hot spare successfully (though undesirably since I want to use the large Samsung disks for the primary array only)
2012-07-26 23:19:21 192.168.135.053 HTTP Log In
2012-07-26 23:19:16 H/W Monitor Raid Powered On
**** The machine crashes spontaneously and I notice the problem and go and restart it.
2012-07-26 23:10:43 Enc#2 SLOT 03 Device Removed
2012-07-26 23:10:43 Enc#2 SLOT 02 Device Removed
2012-07-26 23:10:43 Enc#2 SLOT 15 Device Removed
2012-07-26 23:10:43 Enc#2 SLOT 14 Device Removed
2012-07-26 23:10:43 Enc#2 SLOT 13 Device Removed
2012-07-26 23:10:43 Enc#2 SLOT 12 Device Removed
2012-07-26 23:10:43 Enc#2 SLOT 11 Device Removed
2012-07-26 23:10:43 Enc#2 SLOT 10 Device Removed
2012-07-26 23:10:43 Enc#2 SLOT 09 Device Removed
2012-07-26 23:10:43 Enc#2 SLOT 07 Device Removed
2012-07-26 23:10:43 Enc#2 SLOT 06 Device Removed
2012-07-26 23:10:43 Enc#2 SLOT 05 Device Removed
2012-07-26 23:10:42 ARC-1880-VOL#000 Abort Migration 006:16:35
2012-07-26 23:10:42 ARC-1880-VOL#001 Abort Rebuilding 000:00:07
**** Now the system gives up the migration of the primary array and the rebuild of the secondary array because it can't find any drives left in the system. Of course they have not been touched by me and are still safely snug in the chassis running normally.
2012-07-26 23:10:42 Enc#2 SLOT 01 Device Removed
2012-07-26 23:10:42 Enc#2 SLOT 04 Device Removed
2012-07-26 23:10:42 TVRecordings RaidSet Degraded
2012-07-26 23:10:42 ARC-1880-VOL#001 Volume Failed
2012-07-26 23:10:42 Enc#2 SLOT 16 Device Removed
2012-07-26 23:10:42 Raid Set # 000 RaidSet Degraded
2012-07-26 23:10:42 ARC-1880-VOL#000 Volume Failed
2012-07-26 23:10:42 ARC-1880-VOL#001 Volume Degraded
2012-07-26 23:10:42 ARC-1880-VOL#000 Volume Degraded
2012-07-26 23:10:42 ARC-1880-VOL#001 Start Rebuilding
2012-07-26 23:10:42 Enc#2 SLOT 01 Device Failed
**** At this point the entire enclosure seems to disappear causing all kinds of problems with both Raidsets
2012-07-26 23:10:42 Enclosure#2 Removed
2012-07-26 23:10:33 TVRecordings Rebuild RaidSet
2012-07-26 23:10:24 TVRecordings RaidSet Degraded
2012-07-26 23:10:24 ARC-1880-VOL#001 Volume Degraded
**** It decides the secondary array is broken and grabs my hot spare (which was not at the time reserved to a raidset) and kicks off a rebuild.
2012-07-26 23:10:12 Enc#2 SLOT 01 Time Out Error
2012-07-26 23:09:58 Enc#2 SLOT 01 Time Out Error
2012-07-26 23:09:40 Enc#2 SLOT 01 Reading Error
2012-07-26 23:06:09 Enc#2 SLOT 01 Time Out Error
2012-07-26 23:05:52 Enc#2 SLOT 01 Time Out Error
2012-07-26 23:05:16 Enc#2 SLOT 01 Reading Error
2012-07-26 23:04:50 Enc#2 SLOT 01 Time Out Error
2012-07-26 23:04:31 Enc#2 SLOT 01 Time Out Error
2012-07-26 23:04:21 Enc#2 SLOT 01 Reading Error
**** After 7 hours of expansion, the trouble begins. It says the problem is with Slot 01 but I suspect it's with the entire array and Slot 01 is just the first drive on the list.
2012-07-26 16:54:07 ARC-1880-VOL#000 Start Migrating
2012-07-26 16:54:05 Raid Set # 000 Expand RaidSet
**** Start the expansion onto one of them and declared the other a hot spare
2012-07-26 16:49:24 Enc#2 SLOT 06 Device Inserted
2012-07-26 16:49:17 Enc#2 SLOT 07 Device Inserted
**** Inserting the two new Samsung drives
2012-07-23 01:27:37 192.168.135.053 HTTP Log In
2012-07-22 01:01:00 H/W Monitor Raid Powered On
2012-07-18 16:35:03 H/W Monitor Raid Powered On
2012-06-24 22:27:12 H/W Monitor Raid Powered On
2012-06-11 09:35:44 H/W Monitor Raid Powered On
2012-04-08 22:49:57 H/W Monitor Raid Powered On
2012-04-08 21:37:52 Proxy Or Inband HTTP Log In
2012-03-07 14:03:20 H/W Monitor Raid Powered On
2012-03-07 12:17:23 H/W Monitor Raid Powered On
2012-03-07 12:02:17 H/W Monitor Raid Powered On
2012-02-17 10:44:51 Enc#2 SLOT 01 Reading Error
2012-01-23 09:47:11 Enc#2 SLOT 16 Time Out Error
2012-01-23 08:07:44 H/W Monitor Raid Powered On
2011-11-30 16:45:49 ARC-1880-VOL#000 Complete Init 006:29:08
2011-11-30 10:16:41 ARC-1880-VOL#000 Start Initialize
2011-11-30 10:16:39 ARC-1880-VOL#000 Modify Volume
2011-11-28 09:56:48 ARC-1880-VOL#000 Complete Migrate 111:04:05
2011-11-23 18:52:44 ARC-1880-VOL#000 Start Migrating
2011-11-23 18:52:42 Raid Set # 000 Expand RaidSet
2011-11-23 19:31:04 Proxy Or Inband HTTP Log In
2011-10-30 12:28:14 H/W Monitor Raid Powered On
2011-09-29 19:12:48 Proxy Or Inband HTTP Log In
2011-09-29 19:11:40 Proxy Or Inband HTTP Log In
2011-09-06 09:46:30 H/W Monitor Raid Powered On
2011-08-28 14:41:52 H/W Monitor Raid Powered On
2011-08-15 20:06:45 Proxy Or Inband HTTP Log In
2011-08-12 22:59:41 H/W Monitor Raid Powered On
2011-08-11 18:14:05 H/W Monitor Raid Powered On
2011-08-11 17:33:53 H/W Monitor Raid Powered On
2011-08-03 12:11:47 H/W Monitor Raid Powered On
2011-07-18 22:08:09 H/W Monitor Raid Powered On
2011-07-18 22:03:07 192.168.135.121 HTTP Log In
2011-07-02 00:22:42 192.168.135.121 HTTP Log In
2011-06-21 11:33:39 H/W Monitor Raid Powered On
Thanks everyone!
Jason
