Aug 20, 2009 #1 Z zerodepth n00b Joined Apr 15, 2007 Messages 29 Hey guys, I dunno if it's just me or what, but my top 5.25" cover seems to be pushed in and I can't get it to be flush with the case. It won't budge at all and seems to be stuck. Should I return it back to Newegg? Any help would be appreciated.
Aug 20, 2009 #2 S stiltner [H]F Junkie 2FA Joined Mar 16, 2000 Messages 10,698 Top 5.25 cover. I assume you mean the bay cover? try one of the other covers? Pictures if you can?
Aug 20, 2009 #3 J jamesman32 Limp Gawd 2FA Joined Jan 11, 2009 Messages 445 Remove the drive bay cover and then try putting it back into place? Mine seem nice a flush. No problems at all.
Aug 21, 2009 #4 Z zerodepth n00b Joined Apr 15, 2007 Messages 29 Thanks for your responses guys. I did a bad job of describing the problem but here's a picture that demonstrates my problem. If you look at the top bay, you can see that its bent towards the computer like this ' \ '
Aug 21, 2009 #5 D dynkin n00b Joined Jul 26, 2009 Messages 56 Mine is normal. But I don't like the cdrom bezel so I replace them with normal black bezels.
Sep 18, 2009 #6 T tony27310 Weaksauce Joined Nov 26, 2007 Messages 114 How did you get the cdrom bezels out? did you have to take out the 5.25 cage out?
