Problem with A8N SLI Premium
themyers
I revieved 2 1G 3200 Patriot ram sticks from newegg today (2-3-2-5-1T), and they work fine. When I added 2 512mb sticks from the same manufacture that were rated at same(2-3-2-5-1t) the system would not boot. So the problem is when I populate all the ram slots no boot? Is this a motherboard issue? Any help would be great.
My Specs:
Zalman 7700cu
Athlon 64 X2 4200+@ 2.6
ASUS A8N SLI Premium/Bios 1006.004
XFX 7800GTX@500/1300(and LOVING IT)
2G Patriot (PDP) 3200@2-3-2-5-1T
74GIG Raptor
200GIG WD
120GIG WD
Antec True Power 2.0 550
My Specs:
Zalman 7700cu
74GIG Raptor
200GIG WD
120GIG WD
Check the BIOS.
wow killer rig you've got there. I agree the problem probably has to do with the board not changing the memory timings accordingly (especially the command rate). Try manually setting some conservative timings and then adding the other sticks. I know the older A64's (pre rev. E) didn't like having all 4 slots filled. AMD says that the rev E's handle that a lot better, but who knows. It may still be flaky like that and want a memory divider or something.
But in all honesty, are the 512's really needed? 2 gigs is enough for even the most hardcore gaming rig. I'd take those 512's and use them in another box.
No my command rate is at 1T. Haven't tried the 2T setting yet. I need 3gigs or more to run Solid Works 2005 Cam software properly from my home PC. lol I agree that I deffinatly don't need that for gaming (other than BF2 lol) Thanks alot for the info and if you hear any more problems with other peoples A8N SLI Premium boards drop me a post.
I believe that if you use 4 sticks of anything with an A64, you NEED to set your command rate at 2T. The memory controller can only handle 2T with 4 sticks of ram.
BTW, what are you running your 4200+ vCore at in the bios on the Premium? Actually, I should just ask what are your settings for voltage, htt, memory, multiplier, temps, etc. I have the board as well and it seems like my voltage isn't being read correctly by the board and I had a post about it a little while back here...
Asus Premium Voltage Question
Definitely try 2T first. If worse comes to worse, I'd ditch the 2x512 and get another set of the 2x1GB identical to the others if you're starved for memory.
yah, i believe it's a widely known issue that you pretty much have to drop back to 2T to run 4 sticks of ram. Great board tho isn't it, i love mine!
Don't want to hijack your thread but did you try running Prime 95. The reason I ask is that I have that same memory (PDC2G3200LLK ) and mobo (check sig) but it will not run at 1T in Prime for no more than an hour of so without erroring out. At 2T, I still get an error but it takes around 6hrs. I'm not overclocking at all.
Patriot's site does not list the timing mode these sticks will run at - are you sure they're rated at 1T. If so, I'm thinking maybe I should RMA mine.
What voltage are you running your memory at? I'll bet if you bump your Vdimm, you'll have less errors.
First make sure you've slotted the ram in the proper channels. Channel A should have 1.5gig, and channel B should have 1.5gig. This according to pg 2-11 of the manual. If this doesn't work, change the command rate to 2T.
Later tonight I'll install an extra gig and see what results I get. Of course I'll have to mix types, OCZ + Mushkin but both have same timings so we'll see.
2T timings did the trick. Thanks for the help fellas! I lose some speed/bandwith with 2T timings, but not to much. Thanks again
