Problem Installing Windows 7 on a DH67CFB3 system
aces155
So I just built an ITX gaming system using an DH67CFB3 motherboard. Booting went fine and Windows 7 loaded from a USB. When it searched for an HDD, however, it says that it cannot find the appropriate drivers. Since I don't have an optical drive in this build I copied the Motherboard Install DVD to another USB and plugged that in. The drive is recognized but drivers were still not found.
The bios does see the hard drive, so I am confused what is wrong.
Any ideas?
I think I've wasted my time here.
Best Regards,
Liquid Cool
Are you plugged into USB 3.0 ports? If so, try USB 2.0 (for the Windows install).
Figured it out. It wanted a CD Drive plugged in. NO idea why but once I did plug one in everything worked.
