Problem installing Win7 on new SDD, Urgent help
Ladic
So I am installing a SSD for the first time and trying to install a fresh copy of Win7, however when I have to choose which HD to install win7 in, I choose the SSD but it tells me,
unable to locate system partition or create a system partion
so it wont let me go thru to the next step
is this a full-fledged windows install disk? or is it an "upgrade" disk?
at the disk selection screen, just find your SSD, delete any partitions on it, and then create one new partition. it will then format it with a file system and continue.
Sounds like you have other drives in there so you may want to go into Disk Management and initialize the disk?
I wouldn't install W7 with any other disks in the machine so after initializing the disk I'd unplug the other drives.
thanks, finally figured it out, under hard drives in bios, the SSD was the 2nd option, it had USB HD as first, changed it and worked
also another thing on desktop the SSD is insane fast I get 7.7 on windows index
but before with my WD Caviar Black 640gb my boottime was 48 seconds, now its only down to 38 seconds
POST is POST is POST.
SSDs do nothing for POST time, or pre-OS hardware initialization times.
Do yourself a favor and don't bother with the Windows Index....it means nothing. ;)
Yeah, the biggest difference I've seen is from the time the Windows desktop first appears until all the services/apps are loaded and you have a static fully functional desktop. That used to take some measure of time, and now it is basically no time at all. The wait time until the desktop first appears hasn't really changed much for me.
