B
bostesseger69
Guest
I'm running Vista Ultimate 64bit, q6600 @ 3.6, 4gb ram, 750gb hdd.
I already tried the wiki install guide or whatever, followed it to the dot....didn't work.
I get this error when trying to install reguarly.
OpenSCManager failed:
Access is denied. (error 5)
Unable to remove the previous installation, install failed.
account (domain\user) [Justin_Comp\Justin]: \
password:
confirm password:
Password encrypted into the Registry.
Unable to connect to 'Justin_Comp:8676',
sock error: generic socket failure, error stack:
MPIDU_Sock_post_connect(1228): unable to connect to Justin_Comp on port 8676, ex
hausted all endpoints (errno -1)
MPIDU_Sock_post_connect(1275): unable to connect to Justin_Comp on port 8676, No
connection could be made because the target machine actively refused it. (errno
10061)
Press any key to continue . . .
I keep getting that error, no matter what....when I try to run install.bat as administrator through command, or directly I get this:
'smpd' is not recognized as an internal or external command,
operable program or batch file.
'mpiexec' is not recognized as an internal or external command,
So, what should I do now?
password:
confirm password:
10061)
