Problem getting onboard LAN to work
one1
Hello -
I own an EPoX 8RDA6+ Pro AMD MB. I recently had to format my computer, and since the format my onboard LAN is acting up. It was working fine prior to the format.
It is enabled in the bios, and I downloaded the latest drivers off of the epox website, yet it still won't function. Under device manager, it is listed as "Drivers not installed," and if I try to reinstall the drivers, it says "There was a problem installing this hardware, Access is denied."
Am I looking past something? Any help would be great!
Without knowing what chipset in particular is on that board (Via/Nvidia, etc), I'd say look to see what the chip is for the NIC and then go to the manufacturer's website to get the drivers rather than Epox (Realtek, Nvidia, Via, whatever the NIC is).
My bad, forgot to say it was NVIDIA. I'll go to their site and try for a driver, thanks for the reply.
The Epox 8RDA6+ is an AXP mobo with the Nvidia MCP southbridge. You should download the nForce2 unified drivers off nvidia and install those.
I went to NVIDIAs website, and download the nForce2 drivers for it, but it was the same file that I had gotten from the epox website. I am absolutely stumped as to why I can't get myu onbaord LAN to work.
I restored defaults on my bios, and tripled checked that it was enabled (it was), updated the drivers, yet it still does not recognize it.
Here is a pic of what it shows up as in device manager (I believe):
ANy ideas?
Hmm, I checked the Epox site. It says your motherboard uses the...
LAN:
One RJ45 from onboard Cicada CIS8201 Gigabit Fast Ethernet PHY
I also looked for the drivers on the site but there weren't any. :rolleyes:
I suggest you go google up "cicada cis8201 drivers" or something.
- edit
Trying using windows update to update that driver. Sometimes it works.
OR you could try rolling back to a previous driver...that has helped me on occasion when having LAN issues.
