- Aug 25, 2010
If I want to use an external USB drive on both PC and Mac I have to format it in exFAT, correct?
Yes that is the easiest. Although macOS will do ntfs quite easily like most Linux builds.If I want to use an external USB drive on both PC and Mac I have to format it in exFAT, correct?
My return window ended the day they announced the event.Well, I would be ready to return while you still can tomorrow if the rumors are true later today. If they release M3 Pro/Max today per the rumors - I would 100% return your M2 Pro MacBook if it's still within the two week return window. Going to have a lot of pissed off M2 Pro/max MacBook Pro owners with Apple not sticking to the yearly release schedule.
Yeap. If it makes you feel better they did the same thing to me back in 2019. Except worse. In May of that year they did an MBP refresh. And then in November they did a full machine update. I spent over $4000 on a machine at launch that 6 months later had a machine for half that that was equivalent in speed (other than RAM). So in that situation I "did everything right", and still basically had to take a bath on that loss.My return window ended the day they announced the event.
Where'd you pull that number from?It seems the M3 Pro has lower memory bandwidth than the M1 Pro and M2 Pro: 150 GB/sec vs. 200 GB/sec.
Compare the specs of the M2 Pro to the M3 Pro on Apple's website comparison tool for the MacBook Pro.Where'd you pull that number from?
Though I would stress that that number means nothing in a void. You'd have to wait for benchmarks to know whether that poses any limitations. And I highly doubt, even if true, that it does.
I still would say the same thing, that number doesn't mean anything in and of itself.Compare the specs of the M2 Pro to the M3 Pro on Apple's website comparison tool for the MacBook Pro.
True. Just wanted to point it out.I still would say the same thing, that number doesn't mean anything in and of itself.
You definitely can get at least $1500 for it on fb marketplace as a private seller. But that is still a $700 bath.Trade-in price for my just bought MacBook Pro is around $588 according to Apple's website. LOL.
I wouldn’t worry about it. The pro chip itself has the smallest differences since they cut back on cores which also means a loss is memory bandwidth. No benchmarks yet, but the estimate isn’t high for the m2 pro to m3 pro.Trade-in price for my just bought MacBook Pro is around $588 according to Apple's website. LOL.
Ship that today!I called Apple and they accepted to do a return.
If he isn't satisfied with Apple platforms, I suppose just his money back. But I think the idea would be to move to a base level M3 Pro instead for the same money.What will you get instead?
You're welcome to your opinion of course. But I think your realization that a good chunk of it has to do with what you're used to is dead on. If you switched to Linux, you'd similarly have to go through a fairly large learning curve.I don't have to ship it myself. A courier company will come pick it up from my house.
As for what I'll get instead? Honestly, I think I'm just going to stick with PC for now. Over these last three weeks of using macOS for pretty much the first time, I gradually got to "understand" it but I'm not sure if it "naturally clicks" with me like Windows does. Windows just seems more logical to me on the basis of how it works. If I can explain this properly, it's as if on Windows I get work done without having to think because things are and work how it "naturally" should. On macOS I feel like I am "using the OS" by having to understand its logic. There seem to be constant small annoyances in macOS that I don't have in Windows. Maybe it's because I grew up with Windows and need to spend more time with macOS to truly appreciate it. However, I was always fascinated by Macs because I loved their hardware design and the "fluidity" of macOS but never got to use one properly for an extended period of time. While I now have a much better understanding of how macOS works, I still feel more at home on Windows.
Edit: If I can sum this up based on my brief experience with macOS, Windows feels like a tool while macOS feels like a luxury appliance.
I'm going to be doing some photo/video editing as part of a new contract. I probably could have done it on my M2 Air but figured I'd step up to an MBP when the M3 was released.You're welcome to your opinion of course. But I think your realization that a good chunk of it has to do with what you're used to is dead on. If you switched to Linux, you'd similarly have to go through a fairly large learning curve.
At its core, macOS is BSD. You can run the entire OS from Terminal if you so choose, which is more or less as power user as you can get.
But I will definitely tell you this all comes down to use case. If you don't want or need to run any apps in macOS or don't prefer it, then there isn't any reason for you to continue owning a Mac. The big advantage for someone like you would probably just be long amounts of battery life that you can use for YouTube, browsing, and office tasks etc. If your core usage on a PC is gaming, then for sure macOS isn't for you. Though I am currently enjoying Cyberpunk 2077 on Crossover with it. I still wouldn't recommend it for anyone who wants to game other than casually or is into a vary narrow set of single player games. (Baldurs Gate 3, games from Obsidian like Tyranny, games from Larian, SE, etc).
Similarly if you were a video editor and you needed a mobile machine, your opinion would probably be a lot different after experiencing the M series media engine in a program like Davinci Resolve. Or Lightroom etc.
I agree. The integration with my iPhone was pretty awesome.They key with macOS just like windows is just learning the key combinations for certain things. Once you have that down - IMO, MacOS is better for actual work. Even more so if you're used to using bash/linux and like to make use of the CLI. Finally, if you use an iPhone the integration with a Mac is kind of a no brainer with the text, phone, and handoff integration.
It requires no secondary application(s).Quick question:
If macOS is better for work and productivity than Windows, why do you usually need to install a third-party app on macOS to achieve what you can natively on Windows? For example, on macOS you need to install a third-party app just to be able to have separate scrolling directions for a mouse and the trackpad but Windows does this natively.
Yes, my Logitech mouse does that. I don’t use Apple mice. They are complete garbage, and have been since the original iMac. Still have my IIfx mouse…In Chrome on Windows, if you middle-click on a link it opens the link in a new tab. Can you do something similar on macOS with Safari when using a Magic Mouse (or even a non-Apple mouse) without having to press Command before clicking on a link?
