Dec 3, 2010 #1 F Filter [H]F Junkie Joined Dec 30, 2001 Messages 9,531 if i have a 465gtx running now and i get a 580gtx can i run both cards in my machine un sli ed and be fine? the 465gtx proabbly would be 24/7 and the 580gtx would run when i wasnt gaming.
Dec 3, 2010 #2 DooKey [H]F Junkie 2FA Joined Apr 25, 2001 Messages 16,148 Yes, you can fold on them both even if they aren't in SLI.
Dec 3, 2010 #3 T Tobit [H]ard|DCer of the Month - March 2010/May 2011 Joined Dec 12, 2005 Messages 5,145 Yup, so long as your power supply can handle the load. There is a guide around here someplace for multi-gpu setup. Piece of cake though.
Dec 3, 2010 #4 F Filter [H]F Junkie Joined Dec 30, 2001 Messages 9,531 can you fold if 2 cards are slied?
Dec 3, 2010 #5 DooKey [H]F Junkie 2FA Joined Apr 25, 2001 Messages 16,148 Yes, you can fold with SLI'd cards.
Dec 3, 2010 #6 R-Type [H]ard|DCer of the Month - October 2011 Joined Mar 6, 2006 Messages 2,806 Yes it is almost too easy with the gpu tracker tool from jedi. http://hardforum.com/showthread.php?t=1550668
Dec 3, 2010 #7 S sirmonkey1985 [H]ard|DCer of the Month - July 2010 Joined Sep 13, 2008 Messages 22,412 DooKey said: Yes, you can fold with SLI'd cards. Click to expand... *as long as your not using the 258.96 drivers*
Dec 3, 2010 #8 F Filter [H]F Junkie Joined Dec 30, 2001 Messages 9,531 yeah using that tool. its works wonders
