Hello everyone! Been lurking here for a few months and it seems like I've drilled down through reviews and suggestions on multiple forums on what would be a good setup that will last me a long time.
This will be my first build which I hope will be done over my Thanksgiving break from my university - worst case scenario is that I have to delay my build and order my parts right before my Winter break.
I plan to try and overclock my CPU (Q6600) as well as when I become more familiar with my hardware, my RAM as well.
I also have Dell 2407 (1920x1200) monitor as well, which is why I am aiming for the 8800GT SLI.
CPU: Intel Core 2 Quad Q6600
Video Card: 2 eVGA 8800GT in SLI >> What kind depends on what I can find in stock...
Mobo: EVGA 122-CK-NF68-A1 LGA 775 NVIDIA nForce 680i SLI ATX >> Found this as a good motherboard for SLI as well as for overclocking the Q6600.
RAM: Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800
PSU: PC Power & Cooling Silencer 750 Quad (Black) EPS12V 750W
HDD: Seagate Barracuda 7200.10 ST3250410AS 250GB 7200 RPM >> Plus two other SATA 250GB Maxtor drives from my older (dell, bleh) rig.
Optical: Pioneer 18X DVD±R DVD Burner Black E-IDE/ATAPI Model DVR-112D
HS & Fan: ZALMAN CNPS 9700 NT 110mm 2 Ball Ultra Quiet CPU Cooler
Audio: Don't know... most likely recycle my old Audigy 2 from my older rig.
Case: Ack! I need the most help on this... I don't know what can properly fit all of this with relative ease. I need something with decent airflow as I am in college I never know what my living situations may be. I was leaning towards either a Lian Li PC-V2000B PLUS II or some sort of Cooler Master (stacker) but it seems like there's a few problems here or there that might make the build not so pleasurable.
Any suggestions for a case? How well are my components for compatibility?
Thanks in advance; I appreciate the great community here at [H]ardForum, you guys seem awesome and amazingly knowledgeable about all different kinds of technology.
If anyone could point me also in a direction for a few good places to buy my case and/or 8800GTs that be splendid... unfortunately all I know to trust is NewEgg and TigerDirect (and they're always out of stock with the new 8800GTs) :|
