Pre-socket 2011 cooler compatibility
krogen
I have an older i5 750 system (LGA1156) with an even older HR-01 Plus cooler. Back-plate is currently being used with screw-in pins.
I am planning to purchase an LGA2011 (v1) motherboard and a CPU.
Officially, the HR-01 does not support LGA2011.
However, according to some sites out there, it does support LGA2011.
So, does it or doesn't it? I'm having trouble figuring out if there's anything that I will need to mount it. I've been out of the computer-building loop for a while.
Thanks!
It's more than likely compatible with socket 2011 if you buy the right adapter for it. IT looks like you need this adapter in order to reuse your old HR01:
http://www.amazon.com/gp/product/B00UN05Q6A/ref=s9_hps_bw_g147_i4
On the Thermalright website, it does say it supports the HR01 and socket 2011. Ergo, it should allow you to installed the HR01 on a socket 2011 motherboard.
