1) What will you be doing with this PC?
Mostly web browsing and typing word documents
Up to $350ish (but would prefer not to pay tax haha
3) Which country do you live in?
Bergen County, NJ. Have access to Microcenter in Paterson
4) What exact parts do you need for that budget? Everything as it'll be pre-built
5) If reusing any parts, what parts will you be reusing? None
6) Will you be over clocking?
No
1366 x 768 - 40" LG TV
Within next month
9) What features do you need in a motherboard?
Just standard features is fine
10) Do you already have a legit and reusable/transferable OS key/license? Yes, but since it's pre-built it's not an issue
Dad's current computer is a HP a6130 that's probably like 6+ years old. I did replace the HD to WD640AAKS, 4GB ram, and Windows 7 Home 64-bit a little while back but it's dying and I don't want to put any more monies into it.
Was thinking of maybe getting this computer HP 100B and buy 2GB ram to make it 4GB from microcenter for about $322.90. Are there any other options that might be better? Thanks!
No
Within next month
