it seems my 485w powersupply is showing its age. and i need to upgrade to a higher end powersupplys, heres what ive been looking at:
OCZ 520w powerstream powersupply
OCZ 600w powerstream powersupply
Enermax 600w Noisetaker powersupply
Seasonic S12-600 600W powersupply
Antec TruePower 2.0 550W ESP12V powersupply
heres my system:
1x AMD64 x2 3800+
1x Asus A8N-SLI premium
2x Evga 7800gt
2gigs OCZ PC4000 EB platinum edtion
2x 80gig seagate hard drives Sata
1x 250gigs seagate hard drive sata
2x LG dvd burners
1x audigy 2 sound card
4x 80mm fans
2x 120mm fans
1x vapochill phase change cooling unit
i plan to overclock like crazy so i need alot to power my system, especially those two 7800GT's wich will probably hooked up to watercooling in the future. im thinking the OCZ 520w powerstream, because it has a strong single 12v railing. which apparently helps overclock a little. and its not a bad price. what do you guys think?
heres my system:
1x AMD64 x2 3800+
2x Evga 7800gt
2x LG dvd burners
4x 80mm fans
2x 120mm fans
