Hi folks.
I finally upgraded my computer, and got a i5-2500k, ECS P67H2-A3 and 2x4GB PNY optima 1333.
I kept the rest:
PSU: Antec Neo HE 500W, made by Seasonic AFAIK; bought it in 5/2007, and it has seen a lot of use.
Graphic card: GF 7800 GTX 256 MB
Harddrives, sound card, low power sata cards (no hardware raid cards).
The problem first occured yesterday trying to add a third harddrive: instead of loading windows I got a blinking cursor in the top left corner. I was OC-ing to 4.0ghz, so I returned multi to stock and eventually booted again, but with only 2 HDDs. I only had a PCI sata/pata card installed, beside the GPU.
Today, still at stock clocks I plugged in 4 HDDs (3 are 7200rpm), plus a Creative XFI Xtreme music, and a second PCI-e sata card, and a DVD burner just for kicks, trying to determine wether my PSU was too weak, and as I feared - it didn't boot, bios not loaded. Also the bios time was reset but not the rest of the settings.
I unplugged most of the stuff and now I'm writting this.
At this point I'm inclined to believe that the PSU is not enough, but I'm puzzled, is the i5-2500k suck a pig? I would expect it to run without issue as long as I have a single video card (and I have no intention of going dual GPU, ever).
The PSU has been rock solid until now, but it did power an AMD x2 4600+ Windsor 65W, ECS 6100 mATX card, and 2x1GB DDR2 800. These may be lower power components, but I also had all of the above components, 2 opticals, an extra 1-2 HDDs on ocasion, webcam, fans etc. And I never had an issue.
So what do you think, PSU or mobo?
I kept the rest:
