Hey everyone. I'm about to build a rig and this rig will be solely dedicated to bitcoin. I currently have two 6950s for this purpose but I plan on buying more GPUs as I find suitable 5800 and 6900 models.
Assuming 170-200w each for the cards how big a PSU would I need to support a maximum of five cards? This would be done with a relatively average CPU I'm not sure if I will get something older like an Athlon or Celeron or something new like i3 2100. I'll need further guidance in this regard but it'll be dual core unless more is needed.
One of the important things I'm wondering right now is: usually, an 80Plus certified PSU is more expensive than one that isn't, and that increases as you approach 80Plus Platinum. Is it worthwhile to pay slightly more for the sake of higher efficiency? I doubt the cost difference would even out even after a long time, but what do you think?
If anyone knows about a fantastic deal on a 1000w+ PSU I'd appreciate a link.
Thank you.w
Thank you.w
