NoodleTech
- Mar 14, 2007
Hi guys,
I was wondering if you could help me spec out a new build.
Sound Mastering/Music Production/ProTools/Running a Control Booth for an Auditorium
Under 5K (less than a Mac Pro)
U.S. / Los Angeles
2 Xeon CPU's / Mobo / 24+ GB RAM / at least 512GB SSD Drive for OS and Apps / 2TB Mass Storage Drive / Multiple Blu-Ray Drives / Rackmountable Case / PSU / NVIDIA Workstation Graphics / Cooling (Fans, CPU HSF, etc.)
None
6) Will you be overclocking?
No
Dual 24" Monitors (1920x1200)
In the next few months
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0 / SATA 6GbS / RAID (if it would be beneficial to have 2 SSD's in a RAID setup)
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Windows 7 Ultimate 64-bit -- Should I consider Windows 8 when it is released?
Any input is appreciated. Thanks!
U.S. / Los Angeles
None
No
