Palimpsest
- Dec 26, 2005
Ok, I'm afraid that I may have destroyed my computer, so let me detail what happened and hopefully someone knows what the cause and result is. I had finished putting together a new computer and had plugged it in for the first time. However, when I flipped the switch on the power supply from off to on, sparks started flying out of the power supply. They stopped after a moment and I quickly pulled the plug. Just to be clear, I didn't turn the computer on. I was turning on the power supply. Anyway, here below are the parts that comprise my computer. Thanks in advance
Power Supply-SeaSonic S12-500 ATX12V 500W
Processor-AMD Athlon 64 X2 4200+
Graphics Card-eVGA 256-P2-N527-AX Geforce 7800GTX 256MB
Motherboard-ASUS A8N-SLI Premium Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard
Optical Drive-NEC Black IDE/ATAPI DVD Burner Model ND-3550A
Hard Drive-(2)Seagate Barracuda 7200.8 ST3250823AS 250GB 7200 RPM Serial ATA150
Case-Thermaltake XASER, Armor Series VA8000BWS Black Aluminum/Steel ATX Full Tower
Memory-OCZ 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200)
