Hey guys, I think my power supply is biting the dust, but just wanted some other opinions and info. It's an Antec TruePower330 that I've had maybe a year and a half. It's never given me any problems until a month or so ago. Anyway, when I turn on my computer, it POSTs fine but my hard drive clicks a couple times and then the computer freezes. If I wait a minute and then reset, it boots up fine and runs all day long without a hitch. At first I thought this was an HDD problem, but my drive passes SMART and WD's data lifeguard tools and somebody in another hard disk thread said it sounded like a similar PSU problem he'd had.
So I go and check my voltages, and my +5v looks way low. At POST, my BIOS is reporting a measly 4.19v on that rail. It seems to be around 4.5 when it successfully boots, and runs from 4.65-4.75v while the computer is in use according to MBM (haven't busted out the multimeter yet). It seems like the PSU is not providing enough voltage until "warmed up". Anyway, here's what I have in the box:
Epox 8RDA+
Barton 2500+ @ 3000+
2x256 Geil PC3200 Ultra
1x512 Geil PC3200 Ultra
Radeon 9700np
TDK 48x CD burner
Hitachi 2x DVD-ROM (circa 1998, woot!)
WD 2500JB drive (8meg, 7200rpm, 250gigs)
WD 400(not sure if it's a BB or JB, currently disconnected for testing purposes)
Audigy2
D-Link wireless card
crappy modem
Sunbeam Rheobus controlling 2x80mm LED fans, 2x80mm crappy case fans, 1x80mm tornado, 1x60mm exhaust fan
1x80mm Antec thermal controlled fan
12" blue cold cathode (on a switch and usually off)
So I guess I'm looking for two things. First, is my PSU borked? Rail sag, on it's last legs, overtaxed by my components, etc.? And second, if that's the case, what would be a good replacement? I've read the sticky, but I can't decide whether it'd be a better idea to just get something that works with what I have now or something that's a bit more future proof. I'm not planning on building a new box or any real significant upgrades for at least 6 months. My current mobo has a 20pin power connector and that's it (no extra 4 pin or 6 pin or any of that), got no SATA drives, no SLI, nothing fancy really. As an estimate from the takaman page in the sticky, I need 3amps on +3.3, 41.1amps on +5 (which seems ridiculous), and 8.9amps on +12 with 332W minimum. I'd also rather spend $100 tops if I do need a new PSU, with less being better. Thanks!
Epox 8RDA+
Radeon 9700np
TDK 48x CD burner
Audigy2
crappy modem
