I have an ultra 550W LSU power supply. My original problem started where i got a message, on the screen the the computer must shut down now. So i restarted. To no avail. I tried to go into bios, the bios would open but freeze up where i could not make any adjustments or to see if something was wrong. I have a gigabyte EP45-UP3P MB with a Q8400 cpu, on the gigabyte board there is a sequence of lights that light up letting you know the cpu is powering up. It would go all the way to the top and just freeze there.
So I contacted gigabyte who told me to rma the board. I did. They sent it back i put everything back together and power up just to the bios. I was able to make one move on the bios then it froze up on me again. I am thinking the 12V rail went bad on the psu. I have had the same system running for 6 months no problems. CPU temps were about 55-60C So while I was waiting for the mb i purchased a freezer pro cpu cooler. That the only change i made. The fan was working on the freezer pro. I used artic silver 5. I made sure to clean off both surfaces nice and clean.
the only thing i can think of is the psu. I dont do much gameing so my graphcs card is gforce 9500 GT. I didnt even hook up and of my 2 hard drives yet just to make sure it wasnt them causing the problems. I should be able to get into bios with out a HD hocked up right?
I know the PSU i bought is a piece of junk, I learned that too late . I found this forum after I had purchased the parts. My Bad.
If someone can recomend a decent psu for my set up I would apreciate it. I'm looking to spend about 70 USD. Like I said I dont do much gaming, just basic internet surphing, light photoshop, email, etc. I just want something reliable and if it is the PSU I'm gonna take this one and throw it in the trash can, they cant keep their RMA on it. One thing I forgot to menttion, when the problem first started i moved ligthly the 24 pin connector because i felt it was hitting the door case, I noticed the power go off and on. That is another reason I feel its the psu that and the fact that it started up fone i was in biod for about a good 10 minutes took a break form the whole assembly made one move and it froze after that so i am guessing that the psu is losing power to the 12volt rail, because the fans are all running. Sorry for the long post, but i tried to include everything i know and did to try to correct the problem.
Thanks for your help.!
