Power Regulation Cooling?
Jakalwarrior
How important is power regulation cooling? I recently bought a http://www.msicomputer.com/product/p_spec.asp?model=K9A2_CF-F&class=mb and as you can see from the picture there is nothing cooling the mosfetts. My heatsink is an xp90C with a delta tri-blade so there will be some decent air flow hitting down there.
Would MSI put together a board that would toast its self without aftermarket cooling? I figure if it can handle a phenom then my 65nm 4000+ "probably" wont toast it but what about when I actually do upgrade to a phenom and bump the voltage to overclock?
This boards big brother the platinum version has all sorts of heatpipe stuff going on :/
No they would not, repairing a board under warranty probably costs them the profits of 100 boards sold.
The mosfets are designed to handle very high temps and they have big junctions etc.
That said, anything electronic lives longer and happier with good cooling. Your heatsink blow-by will be more than sufficient for stock operation and mild OC. If I were going to OC a power hungry multi core CPU and water cool that board, I would have a fan directly blowing in that area and if I found some cheap sinks that would fit I might spend the time to slap them on. Reliability and stability at extreme operating conditions would probably be improved. If I had the sinks and the board was not yet mounted and nothing was on TV I might slap them on for the hell of it. I would not lie awake nights worrying about it if I did not as long as there was some air movement around them.
Plat verions has to have something so the suckers that shelled out the cash think they got something. A 40mm fan blowing in that area would probally beat the shit out of a poorly applied, probally not actually contacting 1/2 of the mosfets anyway due to board bow, thick thermal pads etc. heatpipe. Looks xexy tho. ( I can say that because I am one of the suckers that shelled out for a top of the line board and then spend 1/2 day and a trip to town to fix the crappy factory heatpipe).
Just had me thinking because some people said it makes the voltage steadier? And I already bought one for my PLL. Not for any particular reason, but because I had to buy a bracket for my XP90c to make it work with AM2, and I needed something to bump my order over the 3 dollar minimum (2.95... and a 3 dollar min, thats evil).
You are probably right though,that really high CFM cpu fan hitting them with a breeze will probably be enough though. I'll probabyl never switch to water cooling either since I dont give a flip about silence and good air these days is just about as good.
