Power issues with brand new computer (and two before it)
DoctaBu
I made this post a few weeks ago about an issue I was having building a friend's PC:
A couple of weeks ago, my friend came to me asking if I could build both a computer for himself and his brother. Looking up some popular configurations (via Ars Technica and the like), I figured out what to build both of them, ordered the parts, and started building. The only differences between the two computers were that one of them was going to use an old power supply (which was still powerful) and IDE hard drive.
Here are them specs:
Processor: Intel Core 2 Duo E6400 Conroe 2.13GHz
Motherboard: ASUS P5B Deluxe LGA 775 Intel P965 Express ATX
Video Card: EVGA GeForce 7900GS 256MB GDDR3 PCI Express x16
RAM: G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
DVDR: LITE-ON 18X DVD±R DVD Burner With 12X DVD-RAM
Case: COOLER MASTER Centurion 5
PSU: 450W FSP SAGA.
Then, for the first computer (hereafter known as "COMPUTER A"), we used my friend's old 500W power supply and the old IDE hard drive. For the other computer ("COMPUTER B"), we used a new 450W PSU & a new SATA hdd from Seagate.
Anyway, this is how it all went down:
First, I built COMPUTER B. It all came together nicely, and booted up just fine from the get-go. Windows XP and accompanying drivers installed fine, so I moved on.
Here's where the trouble arose. I installed everything just fine into COMPUTER A, just like the other one (this would probably mark about my tenth built PC from scratch), and I turned it on. Booting COMPUTER A up revealed the first warning flag: a warning saying, "overclocking failed!!" Of course, I wasn't trying to overclock anything. So, before continuing, I decided to try to rid of this problem. I tried going into the BIOS and resetting all of the settings there, and actually cleared the BIOS on the motherboard itself twice-- both to no avail-- the error message still would come up... not all of the time, but most.
I decided to ignore the warning and continue anyway. The old hard drive that was in the case had Windows XP installed prior, and although I wouldn't use an old install of an OS to start running a new computer, I wanted to test it out. That didn't work. So, instead, we went out and got a new SATA hard drive (also from Seagate) to install Windows fresh. Booting from CD, it only once got through the initial loading part before saying a part (and this "part" changed every single time) of the CD was corrupted (we had JUST used it to install on COMPUTER B). The one time it made it through, it BSoD'd before we could even format & partition the hard drive.
With COMPUTER B working perfectly (keep in mind, COMPUTER B has only been alive & kicking for about 2 hours-- not much time passed between it running and trying out COMPUTER A), and the parts being almost exactly the same, I tried switching out all of the parts (1/2 of COMPUTER B's RAM, Video Card, HDD [w/ the Windows installed from COMPUTER B], Power Supply, and DVDR drive) save for the motherboard itself in COMPUTER A. No combination successfully booted anything correctly (besides the BIOS & its setup screens), so I gave up, blaming the problem on the motherboard, dying either by a production fault or frying via the PSU.
So, with COMPUTER A down for the count, I replaced all of COMPUTER B's parts back into its case and booted it back up again. It was running fine until, just as I was leaving, the computer suddenly rebooted itself. My friend asked me what to do and I assumed it might've just been a fluke. I left, and by the next morning, they said it "produced a gray flicker every few minutes." Switching monitors & video cards did nothing. Then, soon after that, all was lost when it wouldn't even boot.
And that, folks, is where I am right now. Two computers, neither of which work correctly. We tried taking out the RAM we had switched into COMPUTER A earlier, but it still wouldn't boot. I even took everything off of the motherboard besides the CPU and the power needed to boot it, and it didn't give me a single beep. And, if I know better, it should be beeping quite a bit if it's missing all of its essential hardware.
Did I get so unlucky as to receive two motherboards DOA? Did I make a big mistake in the switch in and switch out of parts between COMPUTERS A and B?
Anyway, we were able to trade all of the parts back in and get brand new ones (all of the same model and whatnot), so now-- whaddyou know-- the same kind of problem is happening.
It seems as though when the computer powers up, it will randomly shut down and startup again, shut down, start up, shut down, and start up until I unplug it (which I do quickly-- it doesn't seem healthy for the computer). We haven't been able to get it past the Windows Setup from the CD before it shuts down on us.
I thought a 450W PSU would easily power the GeForce 7900GS KO and the Intel Core 2 Duo, but am I wrong? This entire thing seems like a power issue...
Any suggestions on what could be the problem?
Thanks a ton!
P.S. I just tried something else... I tried laying the motherboard on a wooden table with just the processor, heatsink & fan, and the PSU plugged into it, and it powered up and back down again... again.
1) Have you tried getting new power supplies? It doesn't matter how much Watts a power supply has, it matters how and where the power supply delivers those watts or amps. So try getting a new decent quality power supply. Here's a cheap but very decent power supply:
XCLIO Goodpower 500W PSU - $50
2) Make sure that the outlet or power strip that you're plugging in the computer to is still good. Had this happen to me once. PC kept restarting until, on a lark, I just plugged it into a different outlet and viola! It worked.
3) Google, download, and run Memtest+. It could be bad RAM. You may have been unlucky and gotten a bad batch of RAM. Run Memtest+ for at least 3 hours or 24 hours max if you want to completely rule out the RAM.
