power buttons
C1utCh
alright, so I am building a custom case, but am having trouble finding power/reset buttons
does anyone know a good place to buy them?
thanks for any help
C1utCh
i do like those Bulgin Vandals, but does anyone know where to find plain silver, or one with a white light?
cant't seem to find a non-lit one, though they are listed on Bulgin's website
Go to radio shack if you can, get a push button switch just like the ones that come with a normal case. A normal switch (toggle) wont work. You just need a short quick connection, not something that will stay on.
Plain silver availible at Newark in One here.
I don't think they made a white one, but you could get a green and swap out hte LED? Colored ones are a good price at FrozenCPU.com.
alright, does anyone have experience putting a new led into the vandal ring ones from frozen cpu?
thanks
