I am running the following:
Biostar Tforce 550
Athlon X2 3600+ (@ 2.8ghz) (cooled by Scythe Infinity)
Sapphire X1650 XT
6GB of Corsair ram
Silverstone Zeus 850W PSU (Etasis built)
Ever since building this system, I have gotten crashes when playing modern games. The screen either freezes or goes black and I have to do a hard reset. I get no artifacts while gaming and older games (Half Life 1) do not cause crashes.
I first thought it was the processor since it is the only component that is overclocked. Using CoreTemp, the temperature only reaches the 40 degree range after several hours of Prime95 (2 instances running).
I thought it was the video card as well. I re-did the air flow and cabling in my case and after several hours of ATITool 3d view running, the GPU maxes out at 73 degrees. The GPU is always at a different temperature when the crashes occur (often below 70 degrees).
I ran the two instances of Prime95 and the ATITool at the same time to get the temperatures I listed above.
I can run Memtest86+ for 24 hours and get no memory errors.
I am really out of ideas. Improving air flow seems to help but not completely. Pointing a small fan at the video card from outside the case does not improve the cards temperatures but seems to stop the crashes. As the chipset is by the graphics card, I am wondering if it is getting cooled by the fan. Can a chipset cause a game to crash (but not Prime95/ATITool)?
I hear a lot about overheating VRM's but don't begin to know how to troubleshoot that.
Biostar Tforce 550
Sapphire X1650 XT
6GB of Corsair ram
