Potential components for new pc
You probably want to ignore the links as they're in Dutch.
CPU: Intel i5 3570 cpu €199,98, 2 years warranty
http://www.mycom.nl/Product/Compone..._campaign=tweakersclick&product_code=50963479
GPU: Club3D Radeon 7850 €212, 50, 2 years warranty
http://club3d.zercom.eu/index.php?dispatch=products.view&product_id=182293
Mobo: GIGABYTE GA-Z77-D3H € 105,80, 2 years warranty
http://www.pixmania.nl/nl/nl/119021...-socket-1155-ch.html?srcid=9170&CodePromo=oui
HDD: WD Caviar Black 1TB 7200rpm 64MB SATA3 €109, 5 years warranty
http://www.informatique.nl/110896/wd-caviar-black-1tb-64mb.html
Cooler: Gelid Tranquillo Rev.2 €32,90, 5 years warranty
http://nl.hardware.info/productinfo/124545/gelid-tranquillo-rev2#tab:prijzen
RAM: Corsair Vengeance DDR3,1600-8GB KIT €46, 95, 10 years warranty
http://www.hardwarewebwinkel.nl/com...utm_medium=membership&utm_source=hardwareinfo
Disc Drive: LG Dvd-brander 24x GH24NS90 €19,61 , 2 years warranty
http://www.micro-mail.nl/web/mm200706.nsf/2011.Home.Link?OpenFrameset&ARTNR=152929
PSU: Nexus NX-5000 R3 530W €65,15, 2 years warranty
http://nexus.zercom.eu/index.php?dispatch=products.view&product_id=771
Case: Corsair Carbide 300R €65,90, 2 years warranty
http://www.4launch.nl/shop/product/120973/-midi-tower-carbide-300r-atx--no-psu--zwart-/hardwareinfo
Total Price: 858.1300 EUR = 1060.3054 USD
The stock cooler of the CPU is probably enough for this system, so maybe I won’t get the Gelid Tranquillo Rev.2 cooler which would cut the price down to 825.2300 EUR = 1019.6542 USD.
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? etc.
High-mid end gaming, web browsing, and for study.
€1000 max.
The Netherlands
Maybe a better Mobo, but improvements over the other components are very welcome as well if not too expensive.
Yes, LG Flatron W2243S-PF monitor.
6) Will you be overclocking?
No, I'm not a pc techy person.
1920x1018
Late August or September.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.I don’t need RAID, Firewire, Crossfire or SLI. I do like USB 3.0, SATA 6Gb/s, eSATA and maybe an onboad gpu although not necessary same for UEFI.
Yes, I already have Windows 7 Ultimate 64bit
Please answer the stickied "ANSWER THESE QUESTIONS FIRST!" so that we can help you better
The stock HSF should suit your needs just fine so you can save money there. However ditch that Nexus PSU since its quality isn't that good. You can get a significantly higher quality PSU for less actually:
http://www.pixmania.nl/nl/nl/9864953/art/antec/pc-voeding-hcg-520-ec-520.html
Motherboard wise, I recommend this MSI mobo instead since it has a better UEFI interface and is cheaper:
http://www.pixmania.nl/nl/nl/11876582/art/msi/z77a-g43-socket-1155-chip.html
If you still need to cut costs, drop the CPU down to the Core i5 3470.
Well, I actually read some good reviews on the nexus psu like here http://uk.hardware.info/reviews/276...-700-watt-conclusion-best-choice-500550-watts
About the mobo of MSI and Gigabyte we're speaking of uk.hardware.info says ''If you're looking for an entry-level ATX motherboard you have the choice between the Gigabyte GA-Z77-D3H (£84), MSI Z77A-G43 (£79) and MSI Z77A-G45 (£102). Click here for their comparison table. The Gigabyte board left the best impression out of those three, because it has the best performance, the lowest energy consumption, Virtu MVP, Dual BIOS and two extra USB 3.0 ports. That said, the MSI Z77A-G43 is also a very good motherboard for a very low price.''
source:
http://uk.hardware.info/reviews/285...-tested-with-ivy-bridge-processors-conclusion
I don't think there's much of a difference between the i5 3470 and the i5 3570 in terms of price/quality, I that case I'll keep the i5 3570
That's not a proper PSU review at all as they are only testing at room temperature. Unless you're planning on leaving that PSU outside of the case, those results mean nothing since a PSU inside a case will run hotter and therefore have different performance. Here's a proper PSU review:
http://hardocp.com/article/2010/02/16/nexus_nx5000_r3_rx5300_psu_reviews/
As shown, it's not that good of a PSU when the higher quality Antec HCG-520 exists.
source:
Still sticking with my MSI recommendation.
The i5 3470 costs €17 less than the i5 3570 and is only cloced 200Mhz lower. If you want to get under that $1000 limit, thats the cut you should do:
http://www.mycom.nl/Product/Componenten-Processor/Intel-Core-i53470,-s1155/1362884
