Potential Coffee Lake CPU Prices Leaked
Megalith
24-bit/48kHz
Finnish technology website iO-Tech has a supposed price list for three 8th-gen CPUs: the four-core, four-thread Core i3-8350K ($199), the six-core, six-thread Core i5-8600K ($299), and the range-topping six-core, 12-thread Core i7-8700K ($420). The rumored October 5 launch date is again mentioned.
The launch prices of numerically comparable chips appear to have increased by 19% to 25% depending on model, though Intel's per-region pricing isn't always a simple currency conversion. We reported about a similar price leak at a Canadian e-tailer just a couple of weeks ago. The leaked Canadian pricing also suggested price increases, though their magnitude was smaller.
Requires new z370 chipset, right? Jeez how many damn sockets and chipsets can Intel release in 2 years?
Worth to note, PC hardware prices are generally a bit higher in Finland.
If any of these prices are correct, i dont regret my 1600x purchase whatsoever
Same sentiment here. Definitely do not regret buying a 1700X. You know damn well if the i7-8700K is ~$400 then it will not be meaningfully superior to the Ryzen 7 chips. It'll be the king of the gaming processors but probably still lag behind the Ryzen 7s in most MT tasks.
Real winner will probably be the ~$200 4c/4t overclockable 8350K with a clear, long upgrade path.
Are there any rumored 4c/8t parts? I need a 4790K replacement. Nothing so far performs better than this chip by any reasonable margin.
i3 will be the new 4c/8t, i5 6c, i7 6c/12. rumors put the 8300 neck to neck to an i7 7700K. the 8700K will be the perfect balance on Single threading performance (gaming) and multi-threaded workloads specially if the rumors of 4.5+ghz base are true
No...it won't be 4c8t...it will be 4c i3, 6c i5, 6/12t i7
