Posts are taking a while to process...
  • Thread starter Deleted member 88227
  • Start date
Status
Not open for further replies.
D
Guest
Might want to check the load on the server. Pages seem to load just fine, but once you hit that submit button it seems to hang for a little while before completing.
Same as yesterday. :(
I'm having the same issue. Slow to post, some attempted double posting (it gives warning).
I have the same issue... What have Steve done this time? :p
Same here. It was fine this morning but has appeared again this afternoon.
It's been fine for me.
Try using a proxy server and see if that's faster. Once in a while, the main route between your ISP and a website will get clogged up to the point that it's slow or unusable. If the proxy is faster, that means the problem is on your ISP's end.
I've seen dozens of cases where large numbers of people start having issues with a website because a hub their ISP uses went down, and all the traffic was temporarily forced over a slower route. If some people have no issues while others do, that's usually a part of it.
ISPs should really have to report when this stuff is going on, it seems to cause a lot of confusion.
If it is freezing while posting, try to open the same thread in a second tab. Usually your post is already there, so you can just close the frozen tab.
Status
