- May 8, 2000
EquaLiZr said:45c idle and 63c load (after an hour of gaming)
this is all stock
Forgot to say fan is at 75% at all times. Duno if that makes any diff
this is all stock
EquaLiZr said:Forgot to say fan is at 75% at all times. Duno if that makes any diff
Are those clock settings 3DMark05 stable?ultramutalisk said:I'm getting a max of 67 C during heat up phase at 577.80 Mhz. It didn't start artifacting until it got to 580 Mhz and I think I'm going to settle for 567 Mhz.
fore1337 said:Are those clock settings 3DMark05 stable?
If so, you're lucky m8!
ultramutalisk said:Yeah, they are... why am I lucky? it seems that they are close to the same that everybody else is getting for the AGP... well, anyways, I just installed the VF700 with AS5 and my idle temperature stayed at 39 C and the load temperature went down from 67 C to 62 C. I'm going to try to run ATI tool again and see if I can increase the core speed any higher. I ended up settling for 560 MHz for the core and 591 MHz for the memory. For some reason, when I overclock the memory, I get some artifacting but very little at 567 MHz, it doesn't happen if I don't overclock the memory. Well, time for ATITool once again!
Oh... I forgot to mention that once I installed the VF700 my CPU temperature went up 3 C, so I guess my case ventilation is not that great.
UPDATE: Well, my max core speed without artifacting is still the same, so I still settled for 560 MHz, so I think I'm voltage limited in this case. But my memory is stable up to 602 MHz, so I'm settling for 596 MHz, so the Zalman memory heatsinks increased my memory overclock by 5 MHz.
Dark_Seph said:I use stock cooling on my x850xt, fan at 100% Speed.
When I have it Idle at 600/600 the temp is 42/38 (give or take)
When I it has full load 600/600, it goes up to around 69/50 (give or take).
That's impressiveDark_Seph said:No volt mod, no artifacts with ATT, I put it through the 3Dmark01 old man in tree scene loop. Also played battlefield 2 for like 8 hours strait, no artifacts nor any issues that I could relate to my video card (now I do have serious PSU problems and I have a feeling that may be limiting me from going higher than 600/600).
http://service.futuremark.com/compare?3dm05=1039645
6823
I want to hit 7k but, until I get a more stable PSU that wont be happening.
Zoramac said:88 idle
111 max load
3dmark05 6906 stock speeds
havent started oc'ing yet, just got the system back together![]()
Buztafen said:...... is this with fire extinguisher aimed and ready?
EDIT: Just realised your probably talking in Fahrenheit...........god please let you be talking in Fahrenheit!!!!!!!![]()
Wildace said:well "stock" my x850xt-PE had a max temp of 110C and would beep and jitter the pcbut after i took the heatsink off and cleaned off the limited amount of factory paste and put on some zalman thermal paste"dont hae any arcticsilver atm" with the stock cooler the load temp is around 85C with the stock cooler, i have the ati tray tool fan setup to 70c 50%, 80c 73% 90c 100%
Buztafen said:Just out of interest, what voids the warranty on a card, ive got a X850XT PE and was thinking of either putting some AS 5 on the stock HSF or getting maybe a Zalman or Silencer?
Also ive noticed im getting what looks like artifacting after playing Doom 3 and exiting to windows. All over the desktop, multi coloured pixels appear everywhere. If i then start Doom again but quit out immediatley it goes back to normal but any amount of playing causes the problem. My card hits 78c max whilst playing even after adjusting the fan speeds using ATi Tray Tools.
....is it RMA time?
Burner27 said:No, that is still acceptible according to ATI. If you remove the stock HSF, you void the warranty. I personally don't give a rats-a$$ about the warranty because the heat alone pushed out by that card with the stock cooler is enough to get me worried about how this card affects my mobo and other component near it. I put a Zalman VF700Cu on mine and my temps were the following:
Stock HSF:
Idle : 55c
Load: 90c+
Zalman VF700CU:
Idle: 40c
Load: 66c
Buztafen said:Sweet, cheers for the info bud.
Any ideas about the apparent artifacting i get?
