EnderW said:I'm getting around 38/58 C Load with the ATI Silencer 5 Rev 2
Mister E said:Wow and I thought my x800xtpe temps with the single slot cooler were bad......![]()
I didn't have the double slot cooler but my clocks are close to x850xt's @ stock so here are my temps anyways.
Stock - 50C idle / 85C load
Zalman VF-700Cu - 41C idle / 63C load
Awesome![]()
Burner27 said:I was about to install my VF700 on mine until I saw your temps after installation -- disappointing compared to the Arctic Silencer. Maybe I should order that one instead?
Wildace said:...with the stock cooler the load temp is around 85C with the stock cooler, i have the ati tray tool fan setup to 70c 50%, 80c 73% 90c 100%
ninethreeeleven said:Drop the 70c to 60c, the 80c to 65c and the 90c to 70c and I bet your load temp drops to 70-75c.
Seriously who ever set the stock fan settings on the cooler wanted those suckers to burn.
Decibel said:Those of you reporting stock cooling and temps under 80 should use a tool that keeps track of your peak temp and make sure that you're not trying to jump out of a game and then checking the temps. In those few seconds it is common for the temps to drop more than ten degrees C.
-dB <- still pimpin his x800pro VIVO @ x800 XT
Thadius Dean said:Not sure if this is load or not but I couldn't find the artifact scanner in the tray tools thing.
Right click in the taskbar icon and go to hardware then overlocking. I think that's where you will find that option.Thadius Dean said:Ok thanks.
Min: 46
Max: 51
