THis is my current ugly setup!
I will switch for a smaller desk. This kind of desk or may be this one: http://www.ikea.com/us/en/catalog/products/30196374/ . And tomorrow I will paint my room in light gray and white! I project to buy a bookshelf ( http://www.ikea.com/us/en/catalog/products/20116274/#/70116276 ) and some wall shelves ( http://www.ikea.com/us/en/catalog/products/S19856861/ ). But i don't know if I take all my furnitures in white or black....
Made so many changes since the last time i posted up if i ever did LOL. New monitors as the 2 i had weren't enough and mismatched sizes made me rage. New desk because of the monitors. And i'm sure the rig is probably about the same if not it is.
It's this: http://www.mockett.com/furniture-hardware/wire-cable-management/wire-managers/wm3.html
I also used it on my home theater. It's held by on 1/2" screws on the desk, don't order the channel with the double sided tape.
OMG I am in love with that site now.
Ok, so I often look through these threads...the desks and set-ups here are amazing.
So you all inspired me to build a desk.
It was made for less than $300 in parts from HomeDepot, and has an acrylic top with monitors embedded in the desktop. I also built an infinity mirror (complete with microcontroller control of the blue LEDs around it)-
The desk height is much higher than a standard desk (can use as a standing or sitting desk, with an architect's chair)- I often use a large Yoga ball as a chair, or simply stand.
Thanks for inspiring me guys (and gals)!
I figured for less than a big Ikea desk I could build my own, so I did. Horray for 2x4s.
-LosT
decided to build one big desk for mine and my roomates triple screen setups
This is my workstation. No work gets done there, it's just for gaming. My computer is presently apart that's why the displays aren't on.
last picture
The display mount is this one: http://shop.easymountlcd.com/Deluxe...-Desktop-Clamp-up-to-28-002-0019-002-0019.htm
Don't let the price fool you, it's worth alot more than that.
I thought is was going to be cheaply built. The steel that it's made out of is 1/4" thick. Everything is welded and it's powdercoated. I wasn't looking at spending $300+ on a triple mount.
if only they made a mount for 30s - would 30s fit this mount even tho its out of spec
Maybe get this one: http://shop.easymountlcd.com/Deluxe...-Desktop-Clamp-up-to-28-002-0019-002-0019.htm
It's for 28" displays but 30's might fit. I would have a look on google to see if anybody tried it. The main thing to look out for is the weight of each display and what type of desk you have.
Can I just ask you two what cases you each have? Thanks.
alas i just might have to "downgrade" to two 3 27s haha
thanks for the heads up
I was thinking of getting a 4" x 4" peice of wood to put between the clamp screws and the desk, just for a little peice of mind.
I haven't found any mounts that support three 30" displays at that price. There are some but they cost $300+:
Maybe you can wall mount the displays.
that's def an option. my 3x30inch project will have to go on hold though as i'm heading back to school
thats what I'm doing with my PLP setup only because my desk is too shallow so I wanted them as far back as possible. The best way to do that is wall mount them. All 3 mounts(one flush and 2 articulating) only cost like $40. Hoping to get them today then start playing with getting them mounted.
edit: mounts arrived, will get started later.
This looks great. Making me have serious considerations against the pole mount some other PLP setups have.
Have you noticed any issues with heat with the 30" being that close to the wall?
