Post your workstation 2010!
Status
Not open for further replies.
mad props for Blade Runner :D:D:D
that almost looks like the New American Orchestra "soundtrack" version I have on vinyl.
It actually is the vinyl. I framed it. :D And Blade Runner is by far my all time favorite movie. It's framed next to my Story of Star Wars vinyl. I found both records at a local garage sale. Framed 'em and had instant geek art. :)
I guess dust or animals are not a problem in your household but why. Why are you using WD Green drives to hold up your speakers? :confused:
As said, I can. It's just one drive and all the data on it (yes it has stuff on it) is backed up on another drive and live on a third array. The more you know about computers the more you know that isn't hurting it.
I downloaded the story of star wars in Flac of all things. Its absolutely terrible. And I didn't even get any artwork to hang on the walls!
Couple questions for you...
What speakers are those?
are they "boomy" (hump in bass around the 100-200hz range)?
any eq on them?
Energy c100
Not at all, light on the bass if anything (which I love).
No, but why would you do that? ;)
Energy c100
I knew they looked like energy speakers, just looks a bit different from what I've seen from them in the past... a bit higher end looking :)
Good to hear they sound good...
I feel the same way about EQ :D
is it hte enermax then? i want something lighted and small i can take with the laptop :). laptop has lighted keys but i dont want to use the keyboard on it if i can help it ;)
According to newegg it's not backlit. You should go with the logitech illuminated that was linked above though if you need something like that. It's a great keyboard.
That's a pretty common argument for drunk driving also. Doesn't mean it's not retarded.
Because drunk driving = having speakers on your hard drives.
Also, hasn't the whole speaker magnet harming hard drives thing been disproved multiple times?
Yep that's totally the point I was making. You heard it here fist, placing speakers on hardrives is as bad as drunk driving. As for the magnet it depends on the speaker. Those are probably fine. Doesn't change the fact that they vibrate.
Architectural shot of the interior
Side Profile View
Airflow schematics, positive pressure, which leads to the question: How to combat the dust-buildup?
All intakes are covered by super-fine medical mesh dust filters.
Side view with side panel in.
http://img687.imageshack.us/img687/828/computer01.png[/img
[img]http://img203.imageshack.us/img203/793/computer02.png[/img
Side Profile View
[img]http://img839.imageshack.us/img839/5365/computer02b.png[/img
[img]http://img340.imageshack.us/i/computer04.png/[/img
[img]http://img801.imageshack.us/img801/9633/computer03.png[/img
Side view with side panel in.[/QUOTE]
is the h70 different from the h50 in that it works best blowing out? or you just have it setup that way
Status
