Post Your Tri Sli Temps
Mike211
I have 3x BFGOC2 Im running evga precision tool
GPU1 idle 73 load 87
GPU2 idle 68 load 70
GPU3 idle 59 load 60
seems like your 2nd and 3rd gpu arnt getting used much. 1 and 2 degrees difference from idle and load? you running at 2560x1600? to take full benefit of 3x sli? anything less would be a waste imo.
it could be that his gpu 3 is at the bottom, most airflow... gpu 2 in the middle, and gpu 3 on top taking in most of the heat from the other two.
^ If you can (if space permits), exhaust some heat somehow above the top card. Definitely sounds like the top card is taking a beating heat-wise.
what are you using to load your GPUs? Clearly they are not getting loaded.
It could be that the 1st card is malfunctioning. Over 80c is very hot. My 9800GX2 would crash when the reported temps got to 81-87C. I would put the 1st card in the 3rd slot and see if the temps even out, then.
Sorry, no tri-SLI here, BTW.
