Lian-Li PC-Q08
6x2TB storage, 1x40GB OS, 1xOptical
Next to my old file server
Did you buy that SATA power cable or make it yourself? If purchased, where can you buy that, I have only seen 4 port with connectors that close together.
Lian-Li PC-Q08
I actually just picked up that case to move my parts from another server into. For the price it is not bad. I was not thrilled with the plastic rails that hold the drives in, and the center fans sit a little to close to the harddrives for my taste.I bought this case about a month ago. Had to give up on the hotswap bays (for now) with this casebut the price was pretty attractive ... I think I paid like 68 bucks shipped. I haven't populated the case with any hardware, so I don't have any pictures of my own to post currently... mostly just curious if anybody had used this case before and what they thought of it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147155
...The norco case is pretty deep and if you don't have a rack to put it in or somewhere where it can be isolated (noise) the other case can be better for you.
Santa-
You should turn those drives around and put the SATA power and data cables in from behind. Much less chance of pulling on something when tinkering around in the system with the cables out of the way, also makes it neater for when you post it to the rate my cables thread![]()
How do all you guys with the 5-in-3 bays justify the cost of the build? It's gotta cost at least $300, or even up to $500 for this setup. Why not just buy a Norco product? They cost less, and they're have better build quality than a custom and retrofitted case.
Coolermaster RC-590
http://www.asposium.com/WHSv2.3---Side.jpg[IMG]
[IMG]http://www.asposium.com/WHSv2.3---Front.jpg[IMG][/QUOTE]
you know anywhere that still sells that case?
or a similar one?
Only a 5bay? I expected the 9bay VMAX.
is there any backup method for this?
Would it be possible to use SAS backplanes instead of SATA multiplex that you are using?It's based off of the backblaze pod 2.0 enclosure, we modified it to remove the 2 power supplies into a enterprise redundant power supply and have it configured with an E-ATX Tyan 8230 motherboard with dual G34 sockets currently using a single 8 core operton
we're going to be using a custom rolled version of Fedora Core 8 x64 that we've built an iSCSI stack for and extended volume support for DRBD to handle the large volumes. If interested in the software I can provide further information.
We're using this as a Replication Target for some Legacy EMC equipment and a Dell Equalogic unit that we'll be replacing with these configurations here over the next few months.
