jacuzz1 said:400/1100 here , I use profiles. I go stock when surfing and select the oc profile when gaming. Power strip is a very convenient tool
Imitation said:Dude if your 1.4 is sittin a nforce2 board jump into a mobile XP, I just built a comp for a friend with an NF7-S and a mobile 2500+ and we jumped straight to 2.4ghz at 1.7v with an old volcano 9! That will feed your 6800GT alot better for about 90 more bucks if you can afford it. You'll see alot more performance out of it. Even if you don't have a nice mobo if you're not runnin SD ram you probly can still move the multiplier up to increase the speed of the mobile.
Drakensoul said:Anyone with an eVga 6800GT tried removing the heatsink to put Arctic Silver on instead of whatever is there from the factory?
Ifxv said:I'm running 420/1100 like the person stated above. I'm thinking I'll try going even higher.
That's a good idea though to only overclock the board when actually playing games, and let it run stock while surfing. I gave PowerStrip a shot; couldn't get it to work. Could it be that the shareware version is crippled that much? Are there any other tools that allow for profiles based on overclocking?
DigitalEmperor said:all boards are being manufactured by nvidia right now. brands dont matter.
BiGG_MiDDLe_LeGG said:What tools are you guys using to check the temps?
joobjoob said:bytheway have you guys noticed that coolbits 2.0 is out i got a few more driver options with it. just a tip.
theNoid said:whats crazy is .. i hear this card should be running hot as hell for an oc.. but 120c is the cutoff. But lol.. mines running at 59c .. so I use it at that 24/7.
Bead said:I don't see the auto overclock options in the temperature settings... can you help me?![]()
burningrave101 said:You have to install CoolBits first.
Create a new .txt file and add the following:
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\Global\NvTweak]
"CoolBits"=dword:00000003
"NvCplEnableHardwarePage" = dword:00000001
"NvCplEnableAGPSettingsPage" = dword:00000001
"NvCplEnableAdditionalInfoPage"=dword:00000001
Now rename that file to CoolBits.reg and double click on it to add that registry entry to your system.
Now go to Control Panel -> Display -> Settings -> Advanced -> GeForce 6800 GT tab -> Click on the Clock Frequencies tab that is now available to the left.
http://www.nvnews.net/vbulletin/showthread.php?t=29541Visable-assassin said:This is the "normal" coolbits correct?
Where is a link and a walk thru for the coolbits 2.0 as to add back the shit that is removed?
pxc said:This is like getting a 6800 Ultra (without dual DVI) for $299. Thanks, best buy!
No way am I spending $399 on a video card.Hurin said:I trust that you meant to say $399.
pxc said:No way am I spending $399 on a video card.![]()
I meant $299. Best Buy had a preorder deal almost a month ago for $299. They finally shipped last week and I got it about an hour ago.
pxc said:I'm starting off with 400/1100 on a BFG 6800GT OC. It ran at stock speed for only 4 minutes.![]()
I won't really know what the max stable speed is for a few days. I just installed the card a 1/2 hour ago and haven't run much yet besides 3DMark2001 (~21,000 http://service.futuremark.com/compare?2k1=7970354) loops and a quick game of Far Cry.
It runs about 25C over ambient when stressed with that benchmark link above.
This is like getting a 6800 Ultra (without dual DVI) for $299. Thanks, best buy! <3
I didn't feel like typing "rthdribl" so i just referred to it as the benchmark, but I meant that demo.evilchris said:You should run rthdribl when testing max temps. Open it in a window as big as your desktop and watch the load temps. The chip cools off 10 Celcius by the time you exit a benchmark like 3Dmark.
