Possibly getting a SC
heflys20
Whelp, I'm thinking of getting a sound card.......I haven't had one in ages (I think :confused:), and would like to see how it compares to an on-board unit.
Currently, my on-board unit is the Realtek ALC887 8 channels.....(whatever).
In terms of sound cards, I was looking at these potential options:
Xonar DX or D1 (doesn't matter):
Azuntech Bravura (can't find Forte, plus I heard the Bravura uses a software version of the X-FI hardware. Is this true?)
X-Fi Titanium or Fatal1ty Pro Series (are Creative's drivers still bad?)
Anyway, those are the current models that fit my budget. I might be able to do a little more. I mostly play games and listen to music. 60/40 respectively. Also, I heard that the Xonar might be inconsistent in terms of EAX emulation.
heflys20
I had a 5.1 from logitech, which, unfortunately had short in it. Currently, I'm using semi decent (extremely generic) speakers from this brand Cyber Acoustics (?).....I might get better speakers, or simply get a headphone set.
criccio
Fully Equipped
Get good headphones. The Logitechs you did have and the current set will not benefit from anything better then onboard audio.
heflys20
Looking to upgrade my speakers too.....Considering the Logitech-Z-2300, since it's $80 on amazon.
