Gaming
Would like to stay under $500, and only consider "bang for your buck" or "worth it" upgrades.
3) Where do you live?
Boulder, Colorado, yay Microcenter!
Looking at upgrading my video card specifically + anything else that's recommended.
- Intel i7 920 OC'd to 4ghz
- Gigabyte GA-EX58-UD4P
- Mushkin Enhanced Blackline 6GB (3 x 2GB) DDR3 SDRAM DDR3 1600 (PC3 12800)
- Corsair 850 HX
- Gigabyte 4890 1GB
- Western Digital Caviar Black 640GB (main drive)
- Western Digital Caviar Black 1TB (storage)
6) Will you be overclocking?
Yes.
I use two 1920 x 1080 monitors, one as my main display and the other for browsing.
Now.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Don't "need" any new features that I can think of.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, still have my Win7 Pro 64 bit.
Basically I am looking upgrading my video card plus anything else that would be worth upgrading at the moment. Meaning I don't want to replace something that will only offer a very minor performance boost. The only things I can think of besides the video card that "might" be worth upgrading would be switching to a SSD as my main drive or adding another 6 GB memory kit. However, in either case I have no idea what kind of performance boost I would see, if any. Would either change even make a difference for gaming? Also, as far as video cards go, the 6950 2GB model is looking quite appealing at the moment, but the one in the [H]otDeals forum is currently out of stock. What other cards should I consider? Any help or advice would be much appreciated!
Gaming
- Corsair 850 HX
- Gigabyte 4890 1GB
Yes.
Now.
