Possible soyo problems.
broly1718
As per my previous thread ( http://www.hardforum.com/showthread.php?t=892912 ), i think my mobo pci slots might be messed up. i tried 3 different firewire cards and kept getting the same problem. windows would see the card fine, it would have no conflicts, no yellow exclamtion mark, and the camcorder would even see that it was hooked up via firewire.
I also tried a couple of network cards ( currently using usb adapter ) and they did the same thing. the router would see a connection ( the lights anyway ), activity lights would flash on the card, and windows saw it with no problems.
Any ideas?
Don't know if this will make a difference, but what chipset drivers are you using? Did you get the newest ones for your chipset?
I'm not sure what version i have to be honest, heh. What is the easiest way to check?
