HI, i know pretty much nothing about motherboards.
I have a problem with my computer that i have logically narrowed down to the possiblity of something being wrong with my motherboard.
I have an ATI RS300 chipset (ATI RS300 + IXP150) in my SHUTTLE ST61G4B.
My problem is as follows:
I have many USB2.0 ports on the shuttle (at least i think i do). These ports work very well when I have devices such as my mouse, and a printer plugged in. I can also plug in flash drives with no problem.
However, I bought a NETGEAR WG111(http://www.netgear.com/products/details/WG111.php) about 3 months ago and havent used it until now, when i have come home from college and want to connect to my wireless G network i have set up at my parent's house. I did install the device 3 months ago on my computer to see if it worked. First i used the provided drivers, which were a hassle, so then i just removed those and let windows install it. This made the device work so after 1 minute of use i just unplugged it and said ok it works. For the last 3 months my brother has had the device in his 5-year-old computer and it has been working excellently. Ok so when i plugged it into my computer, the ting works well for 5 minutes or so, then loses connection. It doesnt lose connection because it lost the signal, it loses connection because the thing just totally shut down. The thing is, if my mouse is plugged into a usb port at this time, then my mouse stops too. if i try to repair the wireless device (by right clicking) then that process freezes and ctrl alt dlt doesnt fix that. then when i try to restart my computer it hangs when it says "logging off" and then i have to hold the powerbutton in for 5 seconds (which btw i hate doing because i always feel like i am breaking something). furthermore, if i escalate the problem by hitting ctrl+alt+dlt too many times and saying "omgwtf", then it is likely that my mouse will freeze even if it is in the ps2 port.
the inter-connectedness of this situation led me to believe that it is something to do with the motherboard, perhaps some sort of information bandwidth overload or some horseradish like that. again, i have no idea about motherboards, and don't even know if such a problem could exist.
anyways, if it does, i would like to know what i should do. like should i RMA my shuttle, because i can still do that, or can i fix it in the BIOS or somewhere else or whatever
if you have read this whole thing, then thankyou very much and thankyou in advance for any help
-shoes
-shoes
