Possible mistake? Micro Center 9100F $88 PLUS $30 off motherboard
Discussion in '[H]ot|DEALS' started by mazeroth, Oct 5, 2019.
  1. mazeroth
    mazeroth Limp Gawd
    264
    Oct 2, 2015
    Emission and SPARTAN VI like this.
  2. sirmonkey1985
    sirmonkey1985 [H]ard|DCer of the Month - July 2010
    21,513
    Sep 13, 2008
    probably just trying to offload them because they aren't selling.
  3. westrock2000
    westrock2000 [H]ardForum Junkie
    9,109
    Jun 3, 2005
    Likely , what motherboard can you reliably buy for that $88 CPU that you KNOW will work out of the box? When I did a build recently, I really wanted to use to i5-9400F, because it's a great price. But you are limited to Z390 if you want a board that you know will work. The lesser tiers are compatible, but will likely need a BIOS update and your screwed if you don't have a compatible CPU to boot the motherboard. People buying a $88 CPU probably aren't look at $125+ motherboards.
  4. sirmonkey1985
    21,513
    Sep 13, 2008
    microcenters usually pretty good about going through all their boards and updating the bios then put stickers on them so you know which cpu's are supported. they do it with a lot of the amd 400 series and 300 series boards to support zen 2 cpu's. so i wouldn't be surprised if they've done the same to support the F series chips.
  5. westrock2000
    9,109
    Jun 3, 2005
    That's possible, though Microcenter has usually been very friendly with AMD over the years. This was at the Dallas store and the rep there didn't recommend I go with the 9400F if I wasn't looking at the Z390 boards. He said the technicians could check it and do the update, but it would be a paid service. That's just 1 sales rep though....but about 2 months previous I had a similar issue trying to get a AMD Athlon 200GE working on B350 board I got from there. It didn't work, so I exchanged it for a B450. I didn't want to deal with that hassle again.
    I will look for the stickers though in the future, I had not noticed those in the past.
  6. mazeroth
    mazeroth Limp Gawd
    264
    Oct 2, 2015
    I built an i3 9100 with an MSI B360 about 4 months ago (open box motherboard) and it worked just fine. This was from Micro Center. Not sure if they updated the BIOS after it was returned.
  7. kirbyrj
    kirbyrj [H]ard as it Gets
    24,460
    Feb 1, 2005
    I can see a regular i3 9100 with the IGP being worth it, but without one just kills the cost as you're going to spend an extra $45 (based on the MC prices) to get a comparable video card to the Intel IGP. Unless you have a used card lying around or something.
