tim_m
i'm so nice
- Feb 10, 2003
This has been driving me absolutely crazy for quite some time (too long for me to remember when so I can't recall any specific changes).
Very randomly with varying frequency (from never in a day to twice within 30 minutes) my system completely freezes without BSODing. That is to say, the image on the monitor freezes to whatever it is, the mouse and kb are unresponsive. I have a G15 kb and it seems to lose all power. All of its lights go out including the blue key backlighting, the num lock indicator, and the backlight for the lcd screen (the lcd turns blank as well).
There is only one instance where this issue might have happened while I was not currently using the computer, but I can't be sure if it was the same issue. Otherwise, I've only observed it while actually using the computer, I never came back to find it frozen.
Once it freezes, if any sound/music is playing, the last, say, 10th of a second worth of sound loops continuously until I turn the power off via the switch on the psu.
This has occurred occasionally at the login screen after I rebooted from this problem happening a first time.
I don't think overheating is an issue (but by all means correct me), immediately after restarting temps are < 120F in the bios and I set the fans to all be on max performance so they shouldn't be slowing down. The problem has happened when I have not been playing any games so the video card wouldn't be under load/getting hot (presumably). Also, it has occurred both while F@H was running and when it was not (100% vs minimal cpu load).
I have tried upgrading drivers for the video card, onboard sound, mobo intel inf chipset drivers/raid controller as well as disabling onboard components like the wifi and the jmicron sata controller (i have not tried disabling the sound...).
The problem occurs when running at stock (read not overclocked) speeds.
I built this computer and many others and never encountered such an issue. I've also done 3 years of helpdesk work for what that's worth to try to indicate my computer knowledge.
Specs are
I should probably try a bios update but I still wanted to post this first to get any and all advice.
Edit: I just updated the bios to the latest version and the problem still happened (within like 10 minutes after restarting after updating it....
Thanks
Specs are
- Intel Core 2 Duo E8400 Wolfdale
- ASUS P5E3 Deluxe/WiFi-AP
- 2x CORSAIR XMS3 DHX 2GB (2 x 1GB) 240-Pin DDR3 SDRAM DDR3 1600
- EVGA 512-P3-N841-AR GeForce 8800GTS
- 2x Western Digital Caviar SE16 WD6400AAKS in RAID 1 on the Intel controller
- ZALMAN CNPS9500
- ENERMAX INFINITI EIN720AWT 720W
- LITE-ON 20X DVD±R
- LIAN LI PC-A10B case
- Windows Vista Ultimate 32bit (needed 32bit for some specific programs I need)
Thanks
