Possible for Mobo to bottleneck system?
weemanbran
So lately I have really been wondering why my system is running games terribly (graphics card wise). Basically, I am getting between 40-80 fps in Counter Strike: Source on 1280x720 on all high. Usually more toward 40 fps, which seems like it would play fine, but it plays like shit. I have messed with many of the in game settings/tweaks for CS:S but it just plays terrible. I have 0 choke, but it feels like I play with a constant 20+ choke. This is just one example, even World of Warcraft doesn't play well. I have to play WoW on all low settings to reduce the "choke" like feeling.
Here are my system specs:
Mobo: http://www.google.com/products/catal...99821039686783
Processor: AMD Athlon 64 x2 3800+
Ram: 2gb Corsair Value Select PC3200
GPU: EVGA 8800gts 320mb
OS: XP Pro
CPU-Z says my Mobo is running at 201mhz. I had my PC built at www.cyberpowerpc.com and I didn't know too much about PC's at the time and didn't think Mobo's affected PC performance. Can a Mobo bottleneck your system like this?
I know its not GPU drivers causing this because I have tried the drivers that came with the GPU as well as the newest on the Nvidia website. Haven't really tried any 3dmarks yet...
Does anyone have any ideas why I am getting poor performance like this?
It may be the graphics card that is the real issue. Reducing the eye candy helps the video card a lot but pushing pixels is pushing pixels and high screen resolutions with low videocard memory is going to kill you. An easy test is to go to 1024x786 and see if the FPS etc. dramatically improves, if so it might be time for a 8800GT or better.
If not,
Thats a decent enough machine hardware specs wise. Offhand without a lot of detailed information I would suspect it has never been "tuned up". By that I mean going through all the bios settings with a systematic testing methodology and "tweaking" for maximum performance. By this I do not mean trying to get some high overclock, but instead characterizing the memory and cpu settings to acheive the best performance (and you probally will see some overclock without reducing stability or reliability). This is a time consuming task requiring a plan and plenty of note taking, the first step is to study as much as needed until you understand exactly what each bios setting does and how it might affect other settings. "Auto" settings in the bios are typically not your friends.
Looking at your hardware list the first thing I would do is start booting into memtest86+ and seeing where you memory craps out frequency wise and if you can tighten the timings up. The value ram is CL3 at best and yes that is hurting you a bit. Not 20FPS worth however.
A re-read made this stand out.
"Lately ..."
Was it doing better before ? If so, reformat and reinstall everything and enable the firewall software even if behind a router/DSL modem as you are probally a bot sending out reams of viagra emails in the background while you play.
Do you OC any of your parts?
If not try pushing them alittle see if there is improvement.
If its the same then you know you got a dud on your hands
"Lately" was me starting to get angry at the performance and I have been wanting to solve the issue. It has always been an issue.
I really don't think it has anything to do with the graphics card. The difference between a 8800gts 320mb and 8800gt 512mb is basically non existent.
I haven't tried OCing nor should I have to, to play 2-3+ year old games. Resolution won't really matter till you approach 1600x1200+ on a game like CS:S. A 8800gts should rip through CS:S at 1200x720 on all high settings with no AA. If it helps at all the performance suffers the greatest on servers with more than 16 people. If I am playing a good 100tic server 4v4 or something on a mildly small map i will get 80+ fps and nothing that makes it feel like I am getting choke. Not really sure if that helps at all...
The motherboard is only a bottleneck if it restricts your overclock (ie it doesnt have a high max FSB) or you have not installed good drivers for the chipset and other components.
Reviews of todays motherboards demonstrate very little difference in performance at the same clock speeds, so there isnt a problem of this nature.
The reason you are getting low fps is because an Athlon x2 isnt a good match for todays faster cards.
A 2.8GHz x2 cannot drive an 8800GT to its max.
Overclocking your CPU will reap big benefits and if its not enough, a C2D system will get you even more.
At the moment, overclocking your graphics card will give no benefit because the CPU isnt fast enough to keep the GPU fully loaded.
Try and see :)
Try and see :)
Thank you!
I figured it was a bottlenecking issue somewhere. Wasn't sure exactly what kind of roll the speed of FSB would play on a system, but if it only affects OCing abilities then my next guess was the processor.
I will try to OC the processor a bit to see what kind of results I get.
The differance between an 8800GTS 320MB and 8800GT is really quite significant. An 8800GT has more then twice the texture mapping performance of the 8800GTS 320MB, conversly the 8800GTS 320MB has significantly more memory throughput. The two are based on two seperate GPUs so they do note share a single identical performance figure.
Even so, the 8800GTS 320MB shouldn't have any trouble ripping through source. I've pretty well reached my conclusion based on the info bolded above, but I'll ask you for one more test anyways: Run the built in CSS stress test. It appears on main menu splash page. I'm betting you'll get your constant refresh rate in fps.
On a high performance server your performance is fine. When a bunch of people are on screen, (where the networking usage is the highest), performance drops. Is it not safe to assume this is a networking issue? Whats your internet setup like? Router make and model, cable type/wireless type, NIC, and your ISPs/ provided downstream and upstream is all useful information.
My 7900GT paired with an Opty 170 runs CSS maxed out with not even a stutter so somethings wrong. Don't listen to the "OMG U NEEDZ A C2D!!" crowd.
Yeah that too. Someones bound to say it sooner or later. Granted, if you own an opty 170 you've probably clocked the bejesus out of it.
*snip*
Not true
26% increase in FPS playing COD4, wouldn't call that non existent...
But also, the previous posters were right that upgrading or overclocking the GPU wouldn't be that beneficial, as it is likely your CPU holding you back.
