popup problem
Mr.BrIaN
How do you get rid of those windows messenger popups?
sorry if its offtopic I didnt know here to put it.
skinlab
administrative tools -> component services -> services (local)
look for 'Messenger'
open it
press Stop
select 'Disabled' from drop down menu
press OK
exit administrative tools
done
XOR != OR
Yeah..that's good. Nevermind the overall problem, let's just bandaid the solution...<temples throbbing>
Get a firewall. The suggestion above is a silly solution to a larger problem, that of you being on the internet without a firewall.
Zardoz
Right on the head!
