Poor WoW Video Performance -- What Gives?
Tower
System specs:
- Athlon 64 3000+ (1.8 Ghz)
- 2 Gb. DDR 400 RAM
- 500 GB SATA 3.0 16 Mb cache HD
- Radeon x800 256 mb (Catalyst 7.2 drivers)
- Soundblaster Audigy (Current Beta Vista drivers)
- Vista Ultimate x64
I have a 22" widescreen LCD, native res. 1650x1080. When I run WoW, I get poor framerates -- less than 20 FPS -- no matter what resolution I pick. I can turn on MSAA, turn texture detail up or down, etc. No change.
The only thing I seem to be able to do is change the Environment and Object draw distance, which improves performance some, but doesn't seem to do a whole lot.
Two puzzling aspects of this scenario:
- Benchmarks with similar systems (and an x800) play the game at 1600x1200 and around 50-60 FPS. So theoretically my system should be able to handle these resolutions?
- My performance seems to degrade slowly over time, getting worse and worse the longer I play, until dropping to around 10-13 FPS at all times.
What gives? Any thoughts as to why my performance is suffering so terribly in WoW? I can play CS:S and DoD:S at 1650x1080, at moderate detail and it runs smooth -- so why should WoW, a game that seems considerably easier to render -- cause my system to crap out?
What have they changed in WoW recently to cause this sudden decrease in performance on your machine?
And even if Blizzard or whoever had done something to WoW, what could you do except report the issue to their tech support?
Thars ya problem right thar /slaps knee
Vista Ultimate x64
or maybe your vista drivers for the video card and/or some setting hiding from you.
But it is not WoW causing your system to crap out, its the crap in your system causing WoW to run poorly.
Unfortunately not very helpfull but at least the problem is properly defined.
The catch here is that I installed an old HD, formatted and installed XP SP2, and receive the same problems.
So.. thoughts?
uh oh, well kinda in same boat, I found this thread and one guy even has an x800 but reports no issue. :eek:
http://www.hardforum.com/showthread.php?p=1030639094
so maybe I shot my mouth off too soon,
hmm 256mb video card trying to push 1650x1080 resolution !!
Need a real video card guru to look, but my impression is that card just does not have the ommph or the memory to push that high resoultion at any decent frame rate.
BillParrish - the x800 will run WoW at 4x AA 8x AF and 16x12 at full draw distance with never dropping below 25 fps EASY (unless you take into account Orgrimar and Ironforge LOL) Anyway - Tower I would look into trying a nother x800 if you have the option. I had an x800 before I moved to my old x1800 - then moving to the 7900GS - then onto my 8800GTS - trust me - that card should run WoW without a problem - hell the x300 will. Go to your local fry's - but a new x800 - I say to do this because A. It should only be around $100 max - and B. If it's not the problem - then it's Fry's - you can take anything back LOL. This at least lets us test one of the variables. If it is not your video card - which I am guessing it is - then it's your ram. Ram goes bad - so does WoW. You have 2 gigs so you should be fine - but if your ram is dying - your kind of effed.
Test
Test
Retest
Retest again
Maybe you will find the solution.....
lolerz
This seems to be more of a WOW problem than a hardware one. Just a stupid thought, but... What mods are you running in WOW? Post a screen of your addons folder, if you can.
System specs:
- 2 Gb. DDR 400 RAM
no. if youre talking a bone stock vanilla x800 you are NOT running it at 1680x1050 @ 60fps regularly unless youre talking piss poor detail. my 6800, even when overclocked, doesnt like going above 1024x768 and remain a decent frame rate most times. and i believe thats faster than the vanilla x800 stock...
if its an x800 xt or pe, than pretty much disregard what ive said.
A stock x800 is going to run a little quicker than a 6600gt. Now, you are trying to run a game at a VERY high res using a midrange card..
Thats your problem.
What people don't seem to understand is that when people say "You can run this game on XXXXXX, its very cpu bound" is that, yea.. you CAN run it. Its going to play like shit though.
The system in my sig barely pulls 60fps constantly with everything turned up.
Don't blame WOW or Vista.. its not that. Its that you expecting high end performance out of your low range parts.
Thats your problem.
Seriously - if your BARELY getting 60FPS in wow on ANY 8800 card - you have some issues you need to look into. People really need to research a little more before they give people advice.
CONSTANT 60FPS is pretty hard at high res in wow, think of vsync. and think of maintaing a CONSTANT framerate over a long period of time, at max everything.
what specific x800 are you running? my gto2 at around xtpe speeds runs WoW at 1440x900 with everything on, 4x AA 16X AF, comfortably between 50-55fps.
i will bet you my left nut he is using the cheap x800 with 128bit memory interface. But really that card isnt that powerful anyway im suprised you can even run it with 4x AA
While I can't offer a suggestion to the OP. Your statement is just wrong. Its the video processor that has the greatest effect on the resoulution you can push. Video memory comes into play when you have games with high-res textures or run extremly high levels of AA. For WoW my 7900GT even at stock clocks will push 1900x1200 at 54-60 FPS (vsync) with everything maxed in game.
I'm using a Sapphire Radeon x800 -- standard -- 256-bit memory interface.
Additionally, the only mod I'm using is CTMod.
Any ideas?
Exactly. When I say CONSTANT, I am talking about an average fps. Sometimes it goes up to 90's, sometimes it dips down to 45. Most of the time it hums around 60-70.
1440x900
24-bit color and 8x multisample.
Everything else forced up as high as it will go.
There is NOTHING wrong with my system other than I am running ddr 400 and most of the reviews you guys have read have been from C2d processors running at LEAST 667mhz. My s939 +3800 x2 running at stock clocks will bottleneck it a little..
On that note, im not going to overclock my shit for +10fps on wow, nor am I going to upgrade for a while for a 2 year old game.. If you bitch about only getting an average 60fps, on any game then you might need to quit caring what others here on [H] think of your rig and just play your fucking games... :rolleyes:
